Question about Frigidaire FPCO06D7MS Professional 6-Slice Convection Toaster Oven
What does error code e02 indicate?
When plugged in displays the e02 on the screen
I had one with the same problem. I found out that this was due to a defective temperature sensor (in my case anyway). The technical name for this part is NTC glass encapsulated thermistor 86k ohm. It is placed against the outer right wall of the toaster oven. if you look into the oven,there are 2 screws holding it( this device is on the other side of the wall and is connected to the controller via a 2-pin white connector. I replaced it and my toaster oven works fine after. This part costs about 1-2 dollars to replace. You have to remove the top cover of the toaster oven to have access to it.
Posted on Oct 23, 2016
  • Anonymous Dec 28, 2016
    Where do you find the new part to order? I have searched and cannot find. Is there a part number I can search?
My toaster oven quit working--the led display lights up just fine but no heat. I unplugged/replugged and it worked! for awhile. Then, the same thing and the plug had no effect.
take it in to an appliance repair shop as it may be the elements or thermostat control that is faulty
get a quote as the repair may be more expensive than a replacement unit
Jun 16, 2017 | Toaster Ovens
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
We have a message on the screen: E02 nothing works
You should take them to the nearest repairer because there malfunction caused by electricity
Mar 08, 2015 | KitchenAid KC0223CU Convection Countertop...
Frigidaire Professional toaster oven is displaying E02 error what do I do ?
Oven temperature too hot. Check and replace oven temperature sensor (RTD)
Sep 27, 2014 | Frigidaire Professional Convection Toaster...
Black & Decker toaster oven won't work
We've had many of these over the years...they seem to run along just fine, and then, one day, they quit. There is no fuse, but if it's the only thing plugged into that wall outlet, the one thing you might check is the circuit breaker on that line. To be sure, plug a lamp into the socket just to make sure you're getting electricity out of the wall.
Sorry to say, it may be time to purchase a new unit.
Sep 14, 2017 | Applica CTO6301 Toaster Oven
How do i set clock
You can get the manual on the link below page 9
http://www.krupsusa.com/NR/rdonlyres/932350FD-628D-4959-879A-AC006C96E9B9/7106/FBC4FBC5.pdf
• When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
Feb 20, 2011 | Krups FBC5 1600 Watts Toaster Oven with...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Setting clock on krups toaster oven
buttons.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Tefal Oven faulty LCD DISPLAY
Hi babypom,
No, the LCD display is a whole piece and need to purchase from the agent.You've to confirm there is LCD voltage, but no display light, to justify is LCD faulty.
Rdgs
alan
Feb 18, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Frigidaire FPCO06D7MS Professional 6-Slice Convection Toaster Oven Logo
3,104 people viewed this question
Top Frigidaire Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Frigidaire Toaster Oven Expert? Answer questions, earn points and help others
