Question about Android Apps
Nook keeps freezing up on me/ what do i do - Android Apps
How do I transfer my library on my old Nook to my new Nook?
How to transfer books from old nook to New Nook? Therefore, to transfer your Nook books to a new Nook, all you have to do is perform a synchronization between the Nook and your Barnes and Noble account. Press the "Power" button on your Nook and hold it down for two seconds to turn on the device. The Welcome screen opens.
How to Transfer Nook Books to a Different Nook ' Chron.com
smallbusiness.chron.com/transfer-nook-books-different-nook-27403.html Search for: How to transfer books from old nook to New Nook?
How do transfer my library on my old Nook to my new Nook Google Search
Feb 07, 2017 | Tablets & eReaders
Will not take a charge a
Barnes & Noble Nook HD
Jan 01, 2016 | Barnes & Noble Nook HD
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
What to do when my nook freezes
try to power down the device and then back up again, then try what you were trying to do.
May 30, 2014 | Barnes & Noble Nook Color
Charging my nook and the screen came on and went to 99% and thats all the screen will do. Charging light shows green and then it sometimes goes back to orange.
It could be your cable, Nook is know to have faulty charging cables, you may have to buy a new one. If you do, here is a tip, search for a pen that you have to click the top to use it, take it apart and take out the spring, now wrap the spring carefully around the charging cord starting at the end where you plug it into the Nook, I attached a photo. This keeps the cord from bending and cracking the wires inside the cable cb393b2a-435d-4472-be29-0ac4a57497ee.jpg
Aug 04, 2013 | Nook HD+
I can't get my nook to work it keeps wanting a password and i don't have one
If you haven't already set up a Nook account,you should. It's easy to do, but you have to have acredit or debt card to do so.
Feb 25, 2012 | Barnes & Noble Nook
How do you unlock your nook, when you forget your password?
From what I have found on this issue it looks like you will need to restore your nook back to factory settings. Any books you bought and backed up from Barnes & Nobles should re-download once you have restored the device and re-registered.
To complete a factory fallback:
1. Turn your device completely off.
2. Power up the device while holding in both the power button and the physical "n" button at the bottom of your NOOKcolor.
3. The device should begin to power up and you will see the welcome screen however keep holding both buttons down and the device will power down.
4. Repeat step 2.
5. When the welcome screen comes up, release both buttons.
6. The device will begin to power on and then a window will pop up asking if you would like to restore your device. Press the "n" button once and again to confirm.
7. The NOOKcolor will restore itself to full factory defaults and will startup as if it were brand new.
8. Re-register your device (while connected to a WiFi network) and you will start over fresh
Mar 10, 2011 | Barnes & Noble nook color eBook Reader
I recently bought a new book and my nook wont let me view it it keeps telling me to put in my name and credit card number
In order to start using your Nook, you'll need to register it through the Barnes & Noble website - I've shared the steps below. Once you've registered it, you will be able to start purchasing and reading books. Please note that you will need to set-up a B&N.com account first. That is done on BN.com and simply click "new user account." Once you have set that up, follow the below Nook set-up steps.
NOOK Set-Up Steps
  1. Charge your new NOOK 3G or NOOK Wi-Fi for 3-hours from a wall outlet using the Power Adapter and USB Cable packed at the bottom of your NOOK box.
  2. Turn on your NOOK by pressing the power button at the top.
  3. Connect to Wi-Fi.
  4. Register your device by entering your BN.com account email.
  5. Tap the down arrow button in the lower right corner of your color touchscreen.
  6. Enter your BN.com password.
  7. Tap Submit
Feb 09, 2011 | Barnes & Noble nook color eBook Reader
Android Apps Logo
750 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
