Question about Diesel Garden
Mahindra tractor stalling
Engine stalls
  • 246 Answers
SOURCE: 2305 tractor keeps stalling out
Hello eireannachcr:
>>Check All the Fuel Connections and Make Sure they are Tight.
>>From Your Description it Sounds like a Loose Fitting or a Bad Compression Washer.
>>A Bad Compression Washer or Loose Fitting will Allow the Fuel to Drain Backwards (sometimes it takes setting for a few days for the Fuel to Bleed Back) when the Engine is Not Running. Once the Engine is Started, it Runs Correctly Until the Air Pocket in the Fuel Gets to the Injector Pump and then the Engine Stalls. The Fuel Behind the Pocket Keeps the Pump and Lines Primed so the Engine will Restart without Bleeding Any Air from the Fuel System.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 148 Answers
SOURCE: Engine stalls
DId you remove the existing gas or just topped it off? If you topped it off, I would dump the fuel and replace the fuel filter, after that I would clean the carb (Spray cleaner).
Posted on May 20, 2009
  • 634 Answers
SOURCE: Craftsman garden tractor engine stalls after
it maybe over heating check fins on sides of motor and clean if needs, another cuase is dirt fuel filter, open gas tank and look to see if there are things or dark spots on bottom of tank, is yes drain clean and flush fuel lines with wd40 change fuel filter if equiped, sediment will settle and inclines or running will move sediment and block fuel flow. when stopped they settle and will run again for time
Posted on Jul 07, 2009
  • 218 Answers
SOURCE: troy built lawn tractor keeps stalling out
Have you checked your air filter..it sounds like it could be dirty and needs replacing..if this dont help..just comment back and i will get it..and i will help you further..Keith
Posted on Jul 08, 2009
wilsodfarm
  • 986 Answers
SOURCE: 1942 farmall tractor stalls after 10 - 15 minutes of bushhogging.
I think you still have a fuel issue like your float level is to low,I hope this helps you
Posted on Sep 10, 2009
Mower quits running when going at a incline or uphill.
Check the gas level.
ride on stalls on incline - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jun 16, 2009 - When its at a certain angle the engine will stall -or- run terribly ... a little water in ..... I am still perplexed by the uphill/slope mower going down. Craftsman Lawn Tractor Stalls Going Downhill
Apr 4, 2010
Old Wheel Horse Problems
May 21, 2008
Hydrostatic Drive Problems??
May 30, 2006
Problem with garden tractor fuel filter
Jul 2, 2005
More results from forums2.gardenweb.com
Sep 25, 2015 | Garden
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 | Garden
Sears lawn tractor
Check fuel tank or cap vent to be sure it is not plugged.
May 03, 2013 | Garden
Engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Feb 26, 2012 | Garden
Tractor stalls
When it stalls, does it die suddenly, as if you turned off the ignition? If so, there may be an electrical problem. Heat causes plastic circuit boards and connectors to expand, and if there's a crack it could open a circuit. One way to find it -- get a can of circuit chiller spray (like this). Run the tractor until it's hot, and stalls. Now spray various ignition parts, one-by-one, testing the tractor after each spray. I'd try the ignition switch, the relays, and the connectors around those. If it seems to fix it, repeat the experiment to be sure. Then replace the bad part.
If it stalls gradually, like it's being dragged down, then it could be mechanical friction - like a bearing or shaft that's heating up and expanding. If you drive around without the blades on, does this still happen? If so, that eliminates the mower deck with its spindles and pulleys as a cause, and suggests it could be the engine. Good luck!
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine stalls
May 20, 2009 | Garden
Diesel engine stalls
Fuel Filter! Check also for water - there should be possibley a drain on the bottom of the fuel filter, try that first
Good Luck
Dec 27, 2008 | 1988 Mitsubishi Pickup
Garden Logo
67 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Wade Mobley
Wade Mobley
Are you a Diesel Garden Expert? Answer questions, earn points and help others
