My laptop Model is Dell Inspiron 1420. it's problem is no power. but when i press "end" key in keyboard then battery icon led on and processor cooling fan move only 5 sec. I open this laptop without battery but not solve this problem.please help me for my problem solve.
    Guru:
  • 452 Answers
Remove the memory module, remove the battery and adaptor, press and hold the power button for 30 sec, (hard reset)
plug in the adptor and try to power up your laptop.
hope this help:
any other suggestion i'm here.
Posted on Feb 14, 2014
zohail
  • 1223 Answers
SOURCE: Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Posted on Mar 07, 2009
RSBennett
  • 54 Answers
SOURCE: fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Posted on Mar 10, 2009
Geekman
  • 32281 Answers
SOURCE: Over heating of my DELL INSPIRON 1420
The fan could be faulty (ie stopped spinning) or the heatsing vents are clogged with dust.
Remove the fan and check/clean the vents/fan. If the fan is faulty replace it.
Posted on Mar 14, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
  • 987 Answers
SOURCE: DELL INSPIRON 1420 BCM2045 INSTALLATION DRIVER
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=555&l=en&s=biz&ServiceTag=&SystemID=INS_PNT_PM_1420&os=WLH&osl=en&catid=&impid=
from here download the bluetooth driver..
Posted on Aug 11, 2009
Dell inspiron 1420 cpu upgrade ???
There are very little things that you can upgrade in an laptop. The processor that you have on your laptop is top end processor in its family and the thae best you can do is to go for a faster core2duo as any other processor will not fit on your laptop motherboard.
Contact your system manufacturer to know about compatible processor for your laptop.
Nov 26, 2012 | Dell Inspiron 1420 Motherboard - KN548
Dell Inspiron 1420 switch off while on at Internet site and it will not start up again when pressing the on button.
you can first try to connect your laptop to an AC power source via the ac adapter, if it fails to charge the battery, then it must be your battery died. try a relacement dell inspiron 1420 battery,which usually lasts longer and is compatibale with your dell and costs much less than the original one!
May 09, 2011 | Dell Inspiron 1420 Notebook
The battery light flashes alternately blue and amber everytime i turn on my inspiron 1420 (even when cool). I've done a health check using the check button on the battery. Indicates battery status fine and...
Hi justlai33
Not to worry, it is a normal process when any laptop is started. It first check if it is connected to power and starts charging if connected to power.
As far as battery life status is good and fine, you can continue working on your laptop.
You will get a pop of notification when the battery life about to end, till then you can work with out any tension.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | Dell Inspiron 1420 Notebook
Hi! can you help me on how to fix my dell inspiron 1420? after cleaning the heatsink fan and re-assemble it again and then i press the POWER it does not run anymore. the tree icon on the top of the...
YIKES!
The most likely scenario which does not assume permanent damage to your system is that there is an electrical short somewhere. Most of the time I have run across this problem, it has been to incorrectly placed or missing screws.
Laptops are a game of precision layering. You need to get a SERVICE manual (not the User manual) for this model at:
http://support.dell.com/support/edocs/systems/ins1420/en/SM/SM.zip
Remove all power (A/C and battery) from the machine and make sure you are grounded. Follow the service manual paying special attention to the screw locations and order of assembly.Also, make sure any ribbon cables or wires are securely and properly connected. Retrace your steps and reassemble the machine and try again.
NOTE: You can clean your heat sink and fan without disassembling your computer. Aside from compressed air, mini-vacuums specialized for laptop computers are available for under $10.00. There are also instructions online for how to you a traditional vacuum to safely clean your laptop are available online. If you must disassemble your laptop, make sure you have patience, a complete set of tools and an accurate Service Manual for that model.
Please leave me some feedback. I sure hope this helps FixYa and any others with similar issues.
Apr 02, 2010 | Dell Inspiron 1420 Laptop
Inspiron 1420 dell says plugged in not charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 22, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Dell inspirion keyboard 1420 replaced new but not working
Not trying to insult your intelligence but are you sure you plugged the keyboard cable all the way and even into the slot and locked it in place. I have had issues where the contacts were not all the way seated in the slot and not fully locked in and the computer knew the keyboard but I had lost partial function. Below is the Dell diagnostics manual for running start up test on your laptop. If your installation is the original it should have a diagnostics partition on it. These steps will show you how to access and run. Just copy and paste the below in your internet browser address bar, hit enter, you can also print it to follow along when the laptop powers down. Good luck,, ParrotHead PC Repair
http://support.dell.com/support/edocs/systems/ins1420/en/OM/trouble.htm#wp1061039
Sep 05, 2009 | Dell Inspiron 1420 Keyboard
Hello I have an Inspiron 1420 that is typing
Hi John,
It sounds to me like you have your Num Lock on. Find the Num Lock key (it should be on the top right of the keyboard) press that key and your keyboard will return to normal.
Regards.
Aug 05, 2009 | Dell Inspiron 1420 Laptop
Diagnostics
While the computer is off, press the Fn key that is placed between the Ctrl and Windows key on the bottom left of your keyboard. While holding it, power on your computer, then wait until you see Diagnostics Boot Selected.
Jun 14, 2009 | Dell Inspiron 1420 Laptop
My s key on dell laptop is sticking , hard to press model 1525
If the system is still under warranty, contact Dell technical support for a replacement keyboard. If it is not, you can buy a new keyboard here:
http://cgi.ebay.com/NEW-Keyboard-for-Dell-Inspiron-1420-1520-1521-1525-1526_W0QQitemZ330252862696QQihZ014QQcategoryZ31568QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
