Question about Sony Action Cam Wi-Fi HDR-AS15
Sony ActionCam AS30V autofocus not working. When I aim the cam to far objects like trees, it sometimes work, but most part of the time, image is blurry.
Latest firmware applied (2.0). Tried to reset several times, didn't work. I've uploaded a video to Youtube, so you can see how blurry it is. http://www.youtube.com/watch?v=ZzMKyxsHYVQ The lens are clean, so is the case.
SOURCE: Playback Problems
Ditto. Old tapes seem to be related to the problem. All I have to do is put in a new tape, play it, remove it, put the old one back in and it will play normally again. I can't explain why. I know the camera has an automatic tape detection feature and I wonder if it is at fault. Perhaps the camera has trouble detecting older tapes and the brains get scrambled. A new tape resets the detector. It's just a guess.
Posted on Jan 10, 2008
mistersony
  • 320 Answers
SOURCE: Sony Handycam DCR-TRV330 Digital Camcorder: choppy hi-motion play
It very well could be a bad drum causing your problem. Be sure that the servicer you select is a Sony trained and recommended service center as they will have the latest bulletins information and training for your camcorder. I just checked on your camcorder and found this bulletin relating to your problem:
Blocking and Choppy Playback (Appears to be a dirty or defective head drum)
Symptoms / Customer Description
Blocking noise in the video during playback. Objects that were taped in motion are choppy.
[Primary Symptom Code: 1330 ]
Cause
Multiple D8 models utilizing the M2000 tape mechanism.
Cleaning the tape path has no effect on improving the symptom.
Solution
Service resolution, clean the point of contact on the video drum where the drum ground arm, ref # 804 comes into contact with the drum assy. After cleaning the point of contact, make sure the drum ground arm #804 is still touching the Head drum
assy.
(Note:After the tape path has been cleaned, the symptom in this issue will persist and lead most technicians to believe that the drum assy itself is defective. Replacing the drum assy complete will correct the problem, but it is not necessary if
the only problem is a dirty contact point on the drum assy from the ground contact.)
So you may not have a bad drum, but only a poor connection. This is why you want a Sony authorized tech to look at it. If you have any further questions, please let me know.
Posted on Nov 22, 2008
SOURCE: cannot view playback!!!!
First thing to determine is if your (Playback Mode) is set for Auto or Hi 8 / 8. Select VTR setting and then select Menu. Scroll to PB Mode and select Auto. Now try playback.
Posted on Dec 29, 2008
  • 67 Answers
SOURCE: Set time and date of Handycam
hi,
its a ruttin problem you just change the LCD FLAP its easily available ,just change it and find the magic,
Posted on Aug 31, 2009
  • 65 Answers
SOURCE: I have a sony bravia
This is actually a common problem with this model, and its surprising that it really does look like a video board (BM board) problem. It is actually a problem with the panel itself.
Here is the fix:
http://www.youtube.com/watch?v=9UrTVEC5LkA&feature=related
This guy was kind enough to post it. I recently did the repair on a KDL-32M3000 and it worked like a charm. Took surprising long, but worked like a charm. I didn't have a 10 Ohm resistor laying around, so I used 2 x 4.7 Ohm resistors in series.
Posted on Dec 09, 2011
Why can't my brand new Meade Polaris 127 telescope not even show me stuff in broad daylight or night. No matter the lens, eye piece, eye, object near or far. I only see eyelashes sometimes if I try.
I suspect that what you have is a combination of two problems:
1. you are very far out of focus,
and
2. you have too much magnification.
Here's what I would do.
Point your scopt at some distant trees. Use your lowest power eyepiece, and run the focus all the way from one end to the other. At some point, you should see the tree leaves....
Nov 15, 2015 | Meade Optics
Owners manual for Sony action cam
What model Sony ActionCam?
Mar 28, 2013 | Sony Cameras
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
Can u use the lenses of minolta slr camera with any other digital camera body today and if yes then models may be suggested
If you have manual focus Minolta lenses, then they are not usable on anything other than other manual focus M35mm Minolta SLR's.
If they have the Minolta autofocus mount then they will physically fit onto any of the current range of Sony Alpha SLR's and also the discontinued Konica Minolta digital SLR's, but there will be some issues:-
  • there will be a 1.5x magnification factor due to picture cropping caused by the digital image sensor being smaller than a 35mm film frame. As an example, a 70-200mm zoom lens will produce an image equivalent to that of a 105-300mm lens if mounted on a 35mm camera. Lens apertures are not affected by the 1.5 crop factor.
  • Earlier Minolta AF lenses relied on the camera body providing the autofocus motor. Later Konica-Minolta and Sony models lack this motor so the lens can only be used in manual focus mode.
  • If you have a later SSM (SuperSonic Motor) equipped lens and want to use it on an Minolta Alpha/Maxxum/Dynax 9 (different model names in different countries), the camera needs a complete additional circuit board which is no longer available.
  • Later Sony Alpha SLR's have far greater electronic communication with the lenses used. Many Minolta lenses will not be compatible and as Sony don't support legacy products there is no fix.
In short, Minolta MD lenses (manual focus) can't practically be used on any modern digital cameras, and Minolta Alpha (autofocus) lenses will physically fit onto a Sony Alpha digital SLR, but will act as if magnified and may not autofocus or work at all on a Sony SLR. But there's no harm in trying.
Sorry there is no absolutely definitive answer for you, but I hope that you now understand why and that you take a moment to rate my reply.
Sep 19, 2010 | Konica Minolta Photography
I have the Olympus E-510. I haven't used it for a while but I have recently had a baby, so I've pulled it out from its hiding spot. The problem is, when I look through the viewfinder it's all blurry and I...
First make sure that the viewfinder glass is clean. If that is not the problem, it may be that the diopter adjustment has been accidentally changed. On the right side of the viewfinder screen is a very small knob. This adjusts the focus of the viewfinder to your vision. Aim your camera at a stationary object and let the camera auto focus. Look throught the viewfinder and turn this knob one click at a time until the image is clearest to you. Hope this helps.
Aug 05, 2010 | Olympus EVOLT E-510 Body Only Digital...
How do you turn off autofocus on Mini DV Sony Handycam?
this is how you disable autofocus for this camera, first set cam to camera mode.using touch panel screen:
1.press FN to display PAGE1
2.press FOCUS
3.select and press MANUAL
4.select and press (icon of person) when subject is too close to focus on or (icon of a mountain) when recording distant subject
5.press (return arrow w/OK) to return to PAGE1
hope this info helps.tnx:)
Apr 16, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Webcam does not work with video chat
You can to try download new drivers, an if that dont work, mybe your camera is broken or something like that...:)
Feb 25, 2010 | Sony VGC-LT16E VAIO 22" All-in-One Desktop...
Canon eos rebel II
Try removing the camera lens and VERY CAREFULLY raise the mirror in the camera. There is another small mirror behind the main mirror that relects the light for the autofocus to work. If the spring on that small mirror is broken (common problem) it can cause the symptom you are experiencing.
You can also check it by aiming the camera at an object above your head with the camera pointed up since that will hold the little mirror in place by gravity. If it works pointed up the spring is the problem.
You can get the spring from Canon. The part number is CS2-6367-000. Canon's parts dept phone number is 1-732-521-7230.
CameraRepairs
Aug 04, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Autofocus does not work ( when ON ) with any lenses .
I remember reading a review of the K100D that mentioned that it had poor low light performance. I know mine has a really hard time focusing in low light situations. It does the sweeping back and forth & most of the time never ends up taking a picture. (Even when it bursts the flash to try to focus.)
I've just started experimenting by using a flash light aimed at the subject I want to focus in low light situations, and the camera seems to be able to focus & take a shot more reliably.
If this works, I'm going to rig up something to hold the flash light underneath the camera so that I can use it more often.
I will post an update if this works!
Take Care & Happy Imaging!
Glen
Mar 15, 2008 | Pentax K100D Digital Camera
F505V can not auto focus red object
Hello Ruchai - Do you mean specifically that it will not focus on these object specifically when in DIM light, or do you mean that it will not focus easily on red objects at all? This is important, because many of the flowers in people's gardens, including my wife's garden, are red. I shoot these all the time, and I have no trouble focusing at all. Now, if you are talking about dim light, it may be that the problem is the dimness of the light more than the color of the object. Pondria has done some interesting work studying that the camera's focus system may be 'seeing' everything as a b&w or grayscale tone in order for its autofocus system to work properly. I do not know if this the truth or not. But it the red color truly is a problem, perhaps there may be a workaround. Focus the camera upon a nearby portion of the plant -- the leaves, a stem, another flower of a different color, etc. Then half-press the shutter button. Finally, reframe the shot and fully depress the shutter button. I will try this today in my garden to see my results with red flowers and autofocus. I will attempt both the regular Autofocus as well as our lauded Spot-focus technique. :) Thanks for more interesting comments.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
Sony Action Cam Wi-Fi HDR-AS15 Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
