Question about Gestetner 10512 Printer
LAN connection gestetner 10512
How to connect printer on LAN
    Habit-Forming:
    New Friend:
  • 104 Answers
Connect the local area network cable to the port of the machine .
press the counter key
press system settings
press the interface key on the screen.
enter the ip aderess and other necessary things in the portions provided the machine.
now go to your computer and open printers and devices.
click on add printer
select add network printer.
enter the ip aderess you entered on the machine and the computer will communicate with the printer and it will will be installed automatically.
print a test page .
if the test page comes out successfully, you have successfully installed the printer.
you can now print your documents form that machine.
good luck.
Posted on Jun 18, 2014
How do I connect my printer directly to my Home Hub?
Dear
If your printer has a LAN port, connect a patch cable from LAN port to the HUB. and install driver by choosing network printer.
Thanks.
Feb 23, 2015 | Office Equipment & Supplies
HOW TO SET PRINTER ONLINE?
hi friend..
this very simple man, just you need one LAN cable and LAN port also.
directly connect your LAN cable to this printer. please search this printer in network by using host name or ip address..
Jun 10, 2014 | HP LaserJet 3055 All-In-One Printer
Limited Connection Error
A limited connection on a Windows PC usually means that there is no connection to the internet on that segment. That is if you connect to the printer via a network switch or LAN. Newer printers can act as a DHCP server/router assigning IP addresses to LAN clients. It has no impact on your LAN if you do not want or need a connection to the internet. However if you want to access the internet from this PC I suggest you get a separate router and use that as the DHCP server on your LAN. Connect the PC and the printer to the router and disable the DHCP server on the printer. Also make sure that all devices (PCs and printer) are using the router as the default gateway. Once again if you don't need an internet connection the limited connection shouldn't worry you.
Nov 15, 2013 | Kyocera Mita Office Equipment & Supplies
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
Describe your bizhub 350 All-In-One Laser Printer Problem I can't connect computer with printer through LAN cable. The LAN connection failed every connection time
check the green light near LAN cable connector is glowing. if not replace the cable. if glowing go to the properties of printer & check if IP address is correct? many printers have unique IP address which u will find in manual of printer. try reinstalling printers installation software from CD.
Aug 25, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Lexmark X3550 printer and need a wireless adapter card, but cannot find this anywhere since Lexmark no longer carries this part. Is there another wireless adapter card that would be compatable...
Try E-Bay, you might be lucky.
Failing that, you can try using a LAN print server, connect the printer to the print server and connect the printer server to your LAN.
Then any computers on your LAN can print to this printer.
OR
Connect the printer to your computer and set it up as a shared printer and if your computer is connected to the LAN then any computer can print to this printer provided you computer and printer are switched on.
Sep 18, 2010 | Lexmark X3550 All-In-One Printer
How to configure 4 Lan + 1 Printer +internet connections
If all your connections are wired, you can use one of the three following solutions.
1. Purchase a router with more then 4 LAN ports on it.
2. If the printer or any of the computers have a wireless network card, then purchase a wireless router and simply connect 4 LAN cables and 1 WLAN.
3. Purchase a hub. Connect 3 computers to the first 3 LAN ports on the router; connect the hub to the fourth LAN port and then connect the last computer and the printer to the hub. In essence both your computer and the printer will share the same IP address (the IP given to the hub) and they should work.
In any of these situations, connect the internet connection to the WAN port of your router.
Thanks,
Pat
Apr 02, 2010 | ASUS RT-N13U IEEE 802.3/3u IEEE 802.11b/g...
Connecting inteface with computer- lan port
The LAN (or Network port) is located on the back of the motherboard. When you connect the cable from the AR 161 to the motherboard, the lights will start to flash - Green = Stable and Orrange = data flashing.
Sep 23, 2009 | Sharp AR-161 Laser Printer
I have a new network printer (Samsung SCX-5635FN) I cant get connection to the printer. I have connected to the LAN port of my router and tried both DHCP and static IP. I have try to change the LAN cable...
have yo installed the printer on to the system ( add a printer ), have you installed the correct driver for the printer
it is not a matter of just connecting leads and expecting it to work
Apr 11, 2017 | OKI C5300n Led Printer
Lan erreur
I think you are probably referring to a LAN ERROR printed out on the paper when the printer is powered on.
If this is the case the printer is fitted with an internal network card, and the network card is not connected to a live network point.
Check you network connection, or if you are not using the LAN card remove it from the printer and you will not see the error printed, this is not an error as such it is an advisory message,
Mar 18, 2009 | TallyGenicom 6312 Matrix Printer
Gestetner 10512 Printer Logo
47 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
