Question about Liberty Furniture BKIT-383-TV00-383-EC00 Ballentine Cherry TV Stand and Hutch
Turn light on for 383-ec00
Pluged light in but can not find a switch or pressure plate
My check oil light keep on blinking on my 97 toyota Avalon. I noticed it started blinking after I changed my radiator. Did I hit the sensor when changing the radiator? Oil is full.
the real question is do you really have oil pressure, check wires on oil sensor pressure switch or sending unit , the other is a pluged oil pressure sending unit but take the time to check oil pressure with a manual gauge if all elese fails
Aug 05, 2014 | Cars & Trucks
383 mag stroker serial number location
You'll find the plate at the Starboard or Portside of the engine, near the flywheel plate.
Usually there is also a sticker on the flame arrestor cover.
Jul 23, 2013 | Mercury Marine 6.3L - 383 Engine Package -...
GENERATOR CLICKS WHEN RUN IS DEPRESSED BUT WILL NOT TURN OVER GOES STRAIGHT TO OC. CHANGED BATTERY NO HELP?
Put it to run while holding the bullseye, you'll see the decimel move, wait for a number other than the run time to show and hit down, up, down, up, down, up then hit the bullseye until you see EC, it should should EC00, if not, select EC00 using up or down, then hit the bullseye until it says save and hit up and the bullseye again.
Aug 21, 2011 | Kohler 12 kW Emergency Power System -...
My Sunpak Auto 383 Super will not fire on or off the camera. When I turn on the switch, the ready/test light lights immediately. I suspect the bulb is burned out, so I wonder if that can be replaced.
There can be one of many parts which is gone :
Flash tube,capacitor,trigger cap.or triggering switch.
Warning as it has 330 volts even when battery is removed do not open if you are not aware of the risks.
Sunpak 383 contains no bulbs inside.
Feb 21, 2010 | Sunpak 383 Super Flash
Galanz Microwave problem
its more likely to be a fuse from the transformer to the cap or the diode.
Sep 14, 2009 | Microwave Ovens
Air compressor switch
That means that when the switch is turned on , and the complessor is pluged into a power outlet, the electric motor will start when the air pressure in the tank drops below 80 psi.and the motor will stop when the pressure reaches 100 psi.
please rate this,
Rob...
Aug 30, 2008 | Air Tools & Compressors
We just set up our 37 in sharp and get no picture
If this is a new set, return it for an exchange. This one sounds like an LCD set which uses a "back light". This back light is not working. This is a warranty repair or exchange.
Dan
Mar 17, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Does not turn on
You need to let it charge for 24 hrs!
Sep 11, 2007 | Jabra BT130 Wireless Headset
Liberty Furniture BKIT-383-TV00-383-EC00 Ballentine Cherry TV Stand and Hutch Logo
44 people viewed this question
Top Liberty Furniture Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Liberty Furniture Furniture Expert? Answer questions, earn points and help others
