Question about Tomtom GPS
How do i open the tomtom 4cs03 case to install a new battery
The battery no longer holds a charge. There is no obvious screws holding the case together. Does the case snap together? If so, where are the pry points?
homemender
  • 158 Answers
SOURCE: battery will not hold charge on tomtom 300
TomTom will not service tomtoms out of the warranty period. I tried them and they dont . They say / argue that there are many companies offering service . I would suggest that the battery is user replaceable with a little bit of DIY knowledge. You need the correct screwdrivers whicth are Torx type. You can buy them cheaply in sets from size T5 up to T20. First remove screen surround by pushing the windscreen mount clip underneath the tomtom , towards the screen. This will push the surrounf out enough for you to grab the bottom of it and pull it off. Next unscrew the 4 torx screws located in 4 holes around the screen. Next , extract the tomtom 'innards' by easing the assembley out of the front of the case. Next , unscrew the 2 torx screws that hold the speaker in place. Next , remove the 2 smaller torx screws UNDER the speaker. This will then allow removal of the plastic clamp that holds the cylinder shaped battery in place.NEXT , unplug the battery ( theres 3 wires go to a little plug on the circuit board ) and withdraw it through the gap left by the speaker. Fit NEW BATTERY ( available off ebay ) and reassemble in reverse order. Of course all this should be done very carefully. DO NOT RUSH. Work on a clear bench and put something soft on the bench to protect the tomtom. DO NOT force anything , it should all come apart easily. If you are unsure , inexperienced at messing with fiddly things or just plain nervous then get someone else to do it.
Posted on Jun 12, 2008
SOURCE: Pls describe the size and type of security screw on tomtom RIDER
I have tomtom rider 1.
There are 3 sizes of Torx screws; 3 sets of 2 screws each.
The largest is at the top back. I watched a fellow on YouTube take the back off. That was very helpful.
Someone called that T6 screw. I found a little set of security torx drivers for this.
The 2 bottom corner screws are smaller and then inside that on each side of the door are 2 more (smaller size but longer) screws.
Then carefully take the back off. There are wires connecting the back to the main board.
Take the card out before you try to take the back off.
Hope it works ok for you.
Ron
Posted on May 26, 2009
  • 4090 Answers
SOURCE: TomTom One XL battery not holding charge but a few hours........
You need to change this battery as if it finally collapses it will ruin the internal components
Posted on Aug 14, 2009
vanherringto
  • 1738 Answers
SOURCE: the battery on my tomtom 720 no longer holds the charge
You can purchase a new battery on eBay for less than $20 including shipping:
Click here: http://bit.ly/bgoqZ0
Posted on Feb 07, 2010
  • 1111 Answers
SOURCE: how do you open this model to check charging port,
Normal 0 hi,
i repair these everyday, so take that in to consideration while evaluating my solutions...be careful what advice you follow on this web site..just because someone claims to be an expert doesnt mean they are.
the title says 4040 but your post doesnt say what model you have, so if you have something other then what i have provided below, please let me know.
Ill assume you have either a 31XX, 4XXX model since those are the ones that are alittle harder to get apart then any other Magellan. Read below what I have replied to others with this question.
You have to be careful taking them apart or youll Break the power port and the head phone port right of the board And it will probably screw the board up. had a few were ppl tried to Take them apart the wrong way and broke the tracers right off the board (now there junk)
Note: always start on the side opposite the power port
Anyway, after the screws are out, use your finger nail if you can,(that's what I use) if not get yourself a very small flat screw Driver (jeweler type) and starting from the side opposite the power port (pictures below) and Head phone port (start on the side the power BUTTON is on, starting at the bottom, Slip it along the seam where the front and back of the case Meet, but don't force it down inside the 2 halfs, you want to just put the blade In far enough so it slides along the seem and that its is separating the 2 just enough to unlock the tabs from Each other see the pics There are 6 taps to break free..2 on the top, 2 on the bottom and 1 on each side....don't worry about the on on the port side. Just tip the back of the case upward and that side will come free on its own. When you put it back together, the port side goes in 1st. Tip the rear of the case up and slide it in under the ports and then lay the back down on to the front half and it will snap together.
IF YOUR GOING TO SOLDER ON THE BOARD, DISCONNECT THE BATTERY AS SOON AS THE REAR COVER IS OFF!
if you need further help, just post back
I Bet I made that as clear as mud. I'm not much of an instructor as you might of guessed by now.
bill
Posted on Jun 20, 2010
Testimonial: "Thanks Bill, Thought it was this kind of hooks but didn't want to break anything. Came apart just as you said it would. Found a bad solder joint on charging port, works great now."
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
TomTom 0ne
There are 4 screws:
1. Remove front bezel
2. unscrew 4 small screws (1 hole has anti tamper tape over)
3. remove "dome" rear of unit.
4. Remove 2 screws holding speaker in
5. Carefully remove all metal tape covering electronics
6. Remove 4 small screws securing PCB to unit
7. Remove 2 screws holding black plastic battery clip
8. Unplug small battery connector from PCB board.
9. remove battery and insert new one
Nov 09, 2007 | Tomtom ONE GPS Receiver
WHY isn't MY TOMTOM CHARGING? It's BEEN PLUGged IN FOR 45 MINS.
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
Tom tom troubleshooting
Your GPS will "freeze" (i.e. stop and shut down) if / when the battery level is low on the TomTom. If you have plugged it in a power source to charge it and the battery indicator shows that it is fully charged ... and then, when you unplug it from the power source, it freezes after a short period of time, it is likely that the battery will no longer hold a good charge.
If it does that while the TomTom is plugged into a power source, it indicates that the battery does not hold a charge anymore.
If this is the case, you may wish to get the battery changed (at an authorized TomTom service center, or do it yourself ... after getting the appropriate replacement battery and the tools/kit, and instructions). Just remember to follow the (initial) charging instructions (after you get a new battery) ... to ensure that the battery will hold a good charge for a long time.
Or junk it and get a new TomTom.
Aug 12, 2014 | Tomtom VIA 135 Automobile Portable GPS...
My navigation program keeps shutting down, and the screen colours have changed automatically.
A likely cause is that the battery is "dead" ... i.e. no longer holds a charge. The GPS runs on battery power, even if it is plugged in. It will work even if the battery holds a (small) charge. But if the battery doesn't hold much of a charge anymore, the device may go into "power saving mode" ... that's where you'll notice the screen brightness goes down, the screen color changes, etc.
If this is the case, you'll want to change the battery.
If this is not the case, it is possible that the navigation software is corrupted. And you'll want to restore it from backup, or download a fresh version (from TomTom.com).
Sep 16, 2013 | Tomtom Navigator 5 1H50.082 GPS Receiver
I have a tomtom xl 330. the device will not start up. I tried to update the application. it still does not work. Please help.
A likely cause is that the battery is "dead" ... i.e. no longer holds a charge. The GPS runs on battery power, even if it is plugged in. It will work even if the battery holds a (small) charge. But if the battery doesn't a charge anymore, the device will not start up, even when it is plugged into a power source.
Sep 04, 2013 | Tomtom XL 330 Car GPS Receiver
My tomtom not comeing on
First make sure your TomTom device (battery) is fully charged. Then press and hold down the ON/OFF button for a few seconds, until the device starts up. Sometimes, you may have to hold it down a lot longer ... like a minute or two .
Sep 02, 2012 | Tomtom GO 720 GPS Receiver
The battery on my tomtom 720 no longer holds the charge
Feb 07, 2010 | Tomtom GO 720 GPS Receiver
Battery will not hold charge on tomtom 300
Jun 10, 2008 | Tomtom GO 300 GPS Receiver
GPS Logo
66 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
