Question about Ovens
What are the setting codes for Whirlpool GMC305PRS01 oven ?
2 Suggested Answers
SOURCE: I have a Whirlpool double
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Posted on Feb 06, 2011
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
Error AM71 UI44 EEWET107 when I replug the oven broil does not work
Whirlpool RBD305PDS Electric Double Oven Repair ... - Fixya
www.fixya.com > Forum > Ovens > Whirlpool
Whirlpool Oven has an F1E1 error code. Whirlpool Ovens ' Answered on Nov 04 ...Whirlpool error code am71 ui44 eewet107 ยท Whirlpool Ovens ' Posted on Nov ...
Sep 12, 2015 | Ovens
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
My Whirlpool gold double oven displays the code F2E3 on the electric panel This problem occurs when I attempt to set the oven to bake. It is now a permanent display
F2 E3: Key held down too long or key is shorted.
Check keypad connector for firm connection. Press Cancel, if error returns after 60s replace keypad.
Jun 28, 2010 | Whirlpool GBD307PD Electric Double Oven
LED display says door. The control pannel wont work at all.
My problem has been repaired by my husband. I do not have the self cleaning on my oven yet the control board thought my self cleaning was on and the door was open. He had to jumper a wire between a connection on pannel to confuse the code and cause the board to set a new error code that could be reset. Which we were able to set the EO code and follow procedure for power disconnect and the board rest. We now have an opperatioal oven. Thank you .
Nov 23, 2008 | Whirlpool SB160PEE Gas Single Oven
Ovens Logo
19 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
