Some network ports from the router where avaya phones are connected all of a sudden stopped powering up the phone but the same points can work well if i connect the computer directly, if i move the phones to different network points they are working, what can make a working network point not power up avaya phone but can connect computer to the network,this is happening in about 4 office spaces out of 20.
SOURCE: Not able to connect to server
The software vpn probably will not work.
Is the vpn tunnel up? Can you ping the IPO? what subnet is the pc?
Posted on Dec 21, 2007
  • 33 Answers
SOURCE: Blank Screen
Try changing the connection on the ethernet switch like the cisco switch if you are you using power on ethernet...
Posted on Dec 11, 2008
SOURCE: IP Phone available for IP office?
If your IP Office is Rel 4.2 or higher, You can purchase a license that will allow you to load a vpn script into the phone. Once you set up your VPN router at corporate, the phone gets plugged into any open internet connection and syncs up with the VPN router and makes a tunnel which then will connect with the phone system giving you a remote IP phone extension of that system.
For the PC, just load client software on it, and it works the same.
Since the tunnel is directly from the device (phone or PC), your home network will not be apart of the office network.
Posted on Mar 12, 2009
SOURCE: One way audio
This is likely a config problem on the NEC or a hardware/software issue on the NEC. Do a Wireshark capture on the NIC on both ends. Examine the RTP streams and see if they are intact. You may have to decode the stream from UDP to RTP depending on if it is a peer to peer call or if it is going through the 8100. Plenty of documentation on how to do that at Wireshark's website.
Posted on Nov 24, 2009
gurvy
  • 223 Answers
SOURCE: Plycom ip330 phone - works fine when connected
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Posted on Aug 29, 2010
Avaya 9640 can't power on when network cable plugged in
Do you have a POE switch? you need power on the port to power the phone...
Nov 06, 2012 | Avaya 9608 IP Phone
How can I set up call forwarding for 4610SW IP?
well you need to be connected to a network ,then u gonna need two network points 1 to power up the phone and another 1 to connect to the motherboard ......and make sure u have access to the internet
Sep 16, 2011 | Avaya 4610SW IP Phone
Avaya 1616 IP phone doesn't take the router IP when assigned statically. There is no DHCP. It shows Bad router after the phone gets a restart.
bad router means that you assigned an IP in the router section, that can not be found on teh network.
You dont have a DHCP server on the network?
Sep 13, 2011 | Avaya 1616 IP Phone
Hi I buy the new phone AVAYA 1616I, but it does not work, it always "finding router" can you help me onm this?
Hi tung_nd,
I see that your are having issues with your AVAYA, see details below.
* First find out the IP address of your Router.
*Inout that IP address in your AVAYA, this should make you AVAYA detect the Router or Network.
*once the Network is detected then you can set you AVAY for use.
Your AVAYA will need an IP address to connect to this will enable it for use, this should fix your concern.
Make sure that you have all the details that you need to be able to set up your AVAYA like the port number that it wwill be using in the aNetwork.
There will be 2 ethernet ports on the back of your AVAY one will be connected to the Router which should give the AVAY the power to turn it ON and the network connection to provide data transfer, the other ethernet port will be connected to your computer this is where the data from the router goes to if you have files that are shared in the network, and if you are running application from a Network.
I hope that this will be helpful regarding your query.
Have a nice day,
mvincentc
Apr 28, 2011 | Avaya 1616 IP Phone
My voice mail stopped working since BT changed its IP address. The PC where the Avaya Phone manager is installed is connected to the network through this BT router. How can I restore the Voice...
What was changed? The IP address of the phone system or the IP of the voicemail PC?
You just need to go into manager and change the IP of where the voicemail is in the SYSTEM>VOICMAIL tab.
Mar 23, 2011 | Avaya 5400 Series 5410 Phone
Avaya 5610 Handset
Has this been fixed yet?
Sep 18, 2008 | Avaya 5610 IP Phone
Avaya phone not working
Yes, check the wiring. Sounds like the blue pair isnt working at that jack.
What happens when you plug that phone into the extension port of the system?
Sep 17, 2008 | Avaya 700340193 Corded Phone
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
