Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik dishwasher s9j1t1 gets stuck on a cycle,it goes on for hours. Also no hot water during the cycle. We did have a power cut yesterday briefly. Any advice welcome!
  • 1894 Answers
SOURCE: TECNIK TDK 795 FAULT
is there the power supply still to the washer??
Posted on Mar 01, 2008
SOURCE: Tecnik dishwasher keeps on washing... and washing!
the "programer" has gone
Posted on Dec 11, 2008
sonicboomele
  • 1557 Answers
SOURCE: after a power cut the unit will not function
i would be of the oppinion you have suffered a power surge and most of the curcuits are fried in my oppinion you need to replace the unit if it can be proven it was a surge your power company by law must pay to replace it to do this you need a pro tech to certify it was a surge (power spike) or if you have home contents insurance its covered by them as well
sorry
good luck
Posted on May 15, 2010
heatman101
  • 43501 Answers
SOURCE: Tecnik 24 in. TKD795/3 Built-in Dishwasher running cold
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on May 18, 2010
alaskabrat11
  • 327 Answers
SOURCE: my tecnik dishwasher(model tdk795) wont
is this a new setup or just happened need more details if it is new setup make sure your hoses are not connected to the wrong water temp supply, trust me it won't work if they are backwards
Posted on Aug 11, 2010
My Tecnik SD13J1 dishwasher (E-Nr SF6 TIE1 GB/21) had water in the bottom of it this morning. As it ran during the night I'm unsure whether the cycle had completed or not. I have removed the lower arm and...
The water usually comes from under the sink it is a 3/8 line from the hot side. it sounds like you have a bad valve or stuck float. check for a small round device in the left or right front corner and makes sure it has nothing under it and is pushed down
Jun 28, 2014 | Dishwashers
Mar 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Tecnik Integrated 795/2
Unfortunately you may have lost the controller or if you are lucky just a loose wire. You can get to all of this by taking the door cover off. If it is not a loose wire the control would be my next best guess. Sometimes they just go.
Sep 06, 2012 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Not enough water in machine
Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Mar 26, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
The dishwasher gets stuck at a certian point during the cycle. How do I fix this
It's possible your water is not hot enough, and the washer goes into a pause heat mode. There also could be a problem with the heating element in the d/w.
Jan 02, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
