Question about NordicTrack Exercise & Fitness
Nordictrack x5 runs only at max speed
Ntk14940
I have a running machine Nordictrack T7.0. It was running fine But now When I press go it runs fine for 10- 20 seconds and stops. Can I please ask your advice on this? Thanks
Hi There, Speed sensor too far from front roller or defective? Lower control board not reaching target "set-speed" when compared to roller feedback may be a failing lower control board. Good Luck
Apr 16, 2017 | NordicTrack Exercise & Fitness
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
How to desasemble to move it to another house?
Hire a professionals, many mishaps and damage to electronics to the machine can occur during a mobe.
Oct 21, 2015 | Nordic Track Nordictrack Incline Trainer...
My nordic trcktreadmill is only running at speed 5
RUN the software calibration for easy diagnose, troubleshooting, and fix it.
However you must adjust the speed sensor, test it for open or faulty, clean it, and tight the plug or connector very well. see the block diagram
God bless you
Nov 19, 2012 | Nordic Track NordicTrack Treadmill, A2550
I have a nordic track 4100i treadmill.
1) Faulty sensor speed try to adjust it face to face magneto motor
2)Sensor speed try to tight the connector very well.
3) Replace if neceesary.4) Main motor faulty or burn. Test 115vac for input measure without load fore easy running.
5) Test the main motor controller board for 115vac input and output for +5VCD,
6) Adjust the deck bel for 2-3" for lift max.
7)Lubricate the deck bel.
8) Test the transformer for input and secondary voltage.
See the block diagram for illustration how the main motor controller has 90% aprox of function of any treadmills.
sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 20, 2011 | Nordic Track Nordictrack Apex 4100i...
When I turn on my nordictrack e4400 it runs for 1 second and then stops
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Mar 22, 2011 | NordicTrack E4000 Treadmill
The Nordic Track machine's controls seem to be stuck. If I press any button other than "3 mph", it fails to respond and nothing happens. However, when I press the 3 mph button, it will only stay at the 3...
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Jul 22, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordic Track EXP1000 that wad purchased
Go to iconservice.com click on manual input manufacturer and model name 1000.
Try this calibration procedure:
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
5) If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
6) The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
7) It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
8) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
9) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.Press the Stop key once and remove the safety key.
If you still do not have belt movement then call iconfitness @ 1-800 999-3756
Jun 26, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a x5, 2003 model, it's not rev above 3000 rmp at most of the time. and it's just accerlarate slowly up to 60 km/h and that's the max speed. the promble will remove when idle the car for 10 minutes...
oh you didnt tell me what country you were from so i assumed it was a gas engine and not a diesel. bmw didnt have that vehicle in the states until last year. could very well be the turbo
Nov 17, 2009 | 2005 BMW X5
Exercise & Fitness Logo
11 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
