Question about Samsung HMX-F90 HD Camcorder White
Use samsung camcorder as webcam on toshiba laptop
I want to use my camcorder as my webcam am I able to do so with the right cords and adapter? If so what do I need to purchase?
Toshiba Satellite L305
best to check with Toshiba or a computer shop . FIXYA does not sell any products
Jan 02, 2018 | Toshiba Computers & Internet
My toshiba is charging but onlythe cord out lets bliking what does that mean
Plug the adapter into the wall outlet or power strip. If using a power strip, make sure the strip is on. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit. Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner. If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter. If the LED light on the adapter is not lit, then the bulb is out, but the adapter is still working.
Jan 20, 2013 | Toshiba Satellite Pro L300 Notebook
TOSHIBA M70 BLACK SCREEN
Check to ensure power cord adapter connection on computer is not loose or broken. Replace if required. Make sure power adapter is the right voltage for the computer. Make sure battery can be charge or replace battery.
Nov 19, 2012 | Toshiba SATELLITE M70-DL3 LAPTOP LCD...
How do I switch on my Webcam on my laptop?
To switch on Webcam, you must install the Webcam drivers and applications. Drivers and applications, adapted to type of laptop. Example: Toshiba Satellite L510-ST3405 to Win XP operating system.
Drivers and applications, you can download here
Toshiba Support Homepage
1. Open link
2. Choose category = Laptop
3. Choose family = Satellite
4. Choose model =
L510-ST3405 - click GO
5. Select operating system = Example Win XP
6. Download driver and application
7. Install driver and application
8. Open application to switch on Webcam.
Nov 10, 2011 | Toshiba Computers & Internet
My Toshiba Satellite refuses to Shutdown or Restart even if I press the power button long.
Hello.
Disconnect the power cord/adapter, flip the laptop and unlock and remove the battery, Reinsert the battery, lock the battery, reconnect the power cord/adapter and power up.
Hope this helps.
Sep 14, 2011 | Toshiba Satellite L645-S4059 14.0"...
My toshiba laptop keeps shutting down only when plugged in to the a/c i have a 305-6853. no overheating works fine if running of the battery alone
This is most likely issue with power cord or on the laptop where you plug it in. Try to separate the cord at adapter and just plug it in without being pluged in to power and see does it create short and shut down your laptop and if not it is possible it is not sending right voltage to the laptop it self. Try a different cord if you have one. Good luck
Mar 17, 2011 | Toshiba Satellite A305-S6859 Notebook
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
My Toshiba satelllite A 305-S6905 System unit laptop just stopped charging , it does not switch on. only yesterday, it was working fine with no problems. it is just two years old .
Please check your battery for right voltage. if the voltage is down check the voltage in your adapter. If there is no voltage in the adapter then you might have to open check the continuity of the cord, normally this cord shorts and the adapter cutts off supply due to a high current error. So if there is shor tremove or other wise check the SMPS circuit for failed components, fuse, recifier, capacitor, driver. However if adapter works there must be supply at the battery terminal of the laptop, if not you have a failure in the charging circuit in the laptop. Hope you check this out one by one. Hope I could help. Good day
Aug 14, 2010 | Toshiba Satellite A135-S4527 Notebook
Hi my toshiba wont turn on the power button would be on but i think its the cord is not connecting to the computer right .. what should i do ?
check if the port or the adapter is damage
if the port, need to send to depot, if adapter, means it need replacement
Jun 11, 2010 | Toshiba Satellite A60 Notebook
Toshiba laptop satellite A135 S4527 power
take it with you when you go and try the new cord before you buy it , Toshiba's are Notorious for the charger cords to be crappy and also the port for the laptop itself to break and need repairing , witch you have to send it to toshiba to get done if that is the case
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Samsung HMX-F90 HD Camcorder White Logo
371 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
