FixYa.com
Tags:
Casio Exilim EX-Z57 Digital Camera
New SD Card wont work - all the others I have do!!
posted by Tasadin on Oct 27, 2007
Ok guys, bought a new SD card Kingston 4gb for our EXz57 and I just get card error everytime I put it in. Have formatted to see if that worked no joy. All the other SD cards we have are fine its just this one. I'm leaning towards a card issue as it has to be plugged into the PC a couple of times before it gets recognised.
Any one got any thoughts???
Thank You
Nicky
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 12, 2007
Helpful (85)
BobsYourUncl
Rank:Apprentice Apprentice
Rating: 85%, 2 votes
I have two Casio Exilim cameras:
One is a EX-Z55 that is 2 years old. I bought a Transcend 4 Gig 150X card but when I tried to use it, the camera formatted it as a 1 Gig. When I read the card, it has 2 partitions, 1 gig active, 3 unused. I used a utility (HP Drivekey CF Card Utility) and wiped out the partitions, reformating it back to 4 Gig. Back in the camera, and same problem. It says "Memory Full" So I format it again with the camera and it goes back to 1 Gig again. I even tried SDFormatter and no luck there either.
After hours of frustration and no results, I formatted it back to 4 Gig and inserted the card into my 2 day old EX-Z77. I turn the camera on and well well well!! It works perfect and the camera recognizes it as a 4 Gig. I tested it and everything is fine in the Z77. As soon as I pull it out and try the Z55, no luck again.
Conclusion: The Z55 does not support the 4 Gig card and the 2 year newer Z77 does.
If I had a 2 Gig card I would try it but all I have is several 1's and a 4. But that may not work either as the camera formats the 4 as a 1. I figure if it supported 2 gigs it would format the 4 as such.
Hope this helps
Comment by BobsYourUncl, posted on Nov 12, 2007
After some more research on my Z55, it says the memory support is for SD and MMC cards.
I checked your Z57 and the same results.
I then checked my Z77 and it supports SD and SDHC, MMC and MMC Plus.
Looks like we are both out of luck on the 4 gig card!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 09, 2007
Not Rated (0)
otterpops
Rank:Master Master
Rating: 90%, 30 votes
I believe any SD cards larger than 2Gb are technically SDHC cards, which are not compatible with all cameras. Kingston is a decent company so I'm guessing it's not because the card is a dud. If your camera doesn't advertise SDHC compatibility then I don't think you can get the card to work in it.
Can you Help with these Digital Cameras problems?
Video feature
I know how to use camera to... Answer This...
my camera wont turn on right
i left it in my purse for... Answer This...
orange flashing light--does not...
my camera turns on and the... Answer This...
Transfering pictures
My camera transfers 2 pictures... Answer This...
Panasonic Lumix DMC-FZ5
I dropped my camera and the... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
