Question about Viking Electronics Door Bell Button Panel
Byron 70217 BELL WIRING
Bought his and there is no wiring connection detail
Plug in byron sx83 stops working,when you take it out the socket then replace it works for a short whill then stops again
I have a different problem with the same model.
Firstly, I think the reason yours stops working is because when you first plug-in / switch-on the power, for the first 10-seconds, the bell is in 'programme' mode. Press the button to connect with the bell and it is then programmed. Sorted. However, if you unplug, have a power-cut, etc. then the button is no longer connected to the bell and needs to be programmed again.
FYI - when in programme mode almost any remote (which is what the button is) can be programmed to ring the bell (e.g. television remote)... so ensure you don't press any other buttons within the 10-seconds 'programme' mode!
My problem is, even after I programme my button to connect, it stops working after a short while. Please let me know if this is happening with yours and if you ahve any solutions.
Thanks,
Jason
Jul 05, 2012 | Cars & Trucks
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
Lost instructions for Byron SX1 wirefree door chime.
i have a byron sx1 door bell and its picking up someone elses help
Aug 24, 2010 | Bell Cocoon Child Carrier
I bought a bell & howell movie projector, need parts
Well Bell and Howell have a website, so i would suggest rtying them first to see where the distributors local to you are. Or you can contact a camera store and see if they will accept it as a repair or supply the parts
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Cameras
I have a byron door bell. If i buy anmother one
This all depends on the design of the unit, if its a fixed frequency then you would need to ensure that the second unit matches the frequency, however if the design allows you to "select"the frequency, usually by a small group of switches then there should be no reason why it wouldnt work, your best chance is to look at your exsisting setup and see if its got any way of setting the frequency, or if it doesnt buy a different unit that is capable or learning a frequency, i apologise for not being able to give a more direct answer on this but i hope it helps!
Nov 05, 2009 | Bell Cocoon Child Carrier
Viking Electronics  Door Bell Button Panel Logo
Top Viking Home Security Experts
Lawrence Oravetz
Are you a Viking Home Security Expert? Answer questions, earn points and help others
