Question about Kyocera Office Equipment & Supplies
I am getting code C6230 machine failure
C6230 machine failure code
Why does my photos art C6230 all-in-one keep saying I need to replace the black ink when the back shows 100%? The printer says it is using colors to make black print
If the machine is just using magenta, yellow and cyan to make black then you get brown, not black, (that why you have a black image unit, because YMC will not make black, color system issue. unless the machine is using yellow,magenta, cyan, then black. Are you using 3rd party toner or OEM cartridges? Did you replace the cartridge before it was required?
May 23, 2015 | Office Equipment & Supplies
How can I get my computer out of safe mode?
With the machine unplugged from the wall remove the battery from the motherboard. Then with the machine still unplugged press the On button for 30 seconds to dissipate any remaining electrical charge on the motherboard. Then re-install the battery, plug the machine back into the wall and see if it will boot normally.
May 11, 2015 | Dell OptiPlex 330 Minitower Desktop...
What does code c6230 mean?
C6230
Fuser thermistor 1 edge break error
Resetting the fuser problem data
Enter 10871087 using
the numeric keys.
Enter the maintenance item U163
number using numeric keys.
Press the start key.
Press [Execute].
The fuser problem data is initialized
Turn the main power switch off and on.
Apr 30, 2014 | Copystar CS-3500i Copier, Printer"
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
At&t 1717 after power failure get beeps and flashing "E2" code. 1717 no longer responds to any command.
Please check the manual, or download it here. At page 7 of the manual, theyl mention you need to call a service-number for help, concerning E-codes.
Oct 10, 2012 | AT&T 1717 Digital Answering Machine
LG LH-C6230 Power button switches off on its own
Yes please this is exactly my problem if anyone can help me with this i will sure be grateful please answer it
Mar 02, 2012 | LG Televison & Video
Kyocera KM1530 photocopier. What does C610 mean? It is comin gup on the display when we turn our machine on.
C610 = Fusing Unit Heat failure. The fusing unit is the part that gets hot and "fuses" the toner onto the paper. The C610 code means that the fuser is not heating up as it should. The 2 most common causes are thermal fuse failure or thermister failure. The thermal fuse will keep the heater lamp from coming on while the thermister failure would cause the machine to not "see" the temperature rising as thus shut down the machine. Either way you will need a service company to come out and diagnose/repair the machine. You must also use the factory service mode to reset the fuser failure code.
Good Luck and Thnak You for using Fixya.
Sep 13, 2010 | Office Equipment & Supplies
On my washer I get the F# code, how can I clear this
Your fault code means Motor RPS failure,Your code will flash when
there is a motor rotor position sensor(RPS) failure.You will need to
call out a technician for this one.
Apr 01, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
56 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
