Question about Sport & Outdoor - Others
There is no indication for wiring of the 70217 bell
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 27, 2012 | Belling Ovens
Door ajar indicator bell stays on w/all doors closed tightly
I just had the same problem. I removed the driver door panel to reveal the wires had come loose from the tape and the window had been rolling down on the wires. The wires were all cut. I spliced the wires back together, secured the bundle back to the frame, and it solved the problem. I hope yours is that simple to solve.
Aug 19, 2011 | 2004 Ford Freestar
Have had major snow storms in the past few weeks. Installed, prior to storms, new door chimes that worked. Since the storms, neither the front nor side bells function. The bell button has a light on...
Most times, doorbell problems are button, especially since indicator light shows you have power.
Take off front doorbell button and see two wires.
These wires are low voltage and safe to touch.
Use screwdriver and touch both screws together, or remove wires from button and then touch two wires together.
If doorbell rings, then replace button.
If bell still doesn't work then scratch two wires together and look for static-type spark that says wires have power.
If wires have power, and you crossed both wires and bell didn't work, then new door chime is suspect.
If wires do not have power, then transformer is suspect.
Open following link to see example transformer:
http://waterheatertimer.org/images/attic-transformer10.jpg
Transformers are located in basement or attic.
Scratch a wire across both screws on transformer and look for static-like spark.
If no power, then check circuit breaker.
Home centers sell transformers in the doorbell section. They are 12 and 24 volt. Check markings on old transformer.
If transformer has power, then new door chime is suspect.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Garden
No radio, door alarm, low fuel indicator bell...
The problem with this is wires under the rear carpet came apart from moisture. Remove the rear seat and carpet molding. Lift carpet in right rear and expose wire loom containing wiring harness. You need to reattach where one orange wire connects to two orange wires. Do this and it is guaranteed to work
Feb 10, 2011 | 2004 Chevrolet Impala
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
c. }}}} = Daily alarm on only
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3171.pdf
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
The warning bell starts immediately and will not shut off when the key is in the ignition even though all seat belts are done up and all doors are closed
I'm an out dated mechanic, but i believe the drivers seat belt assembly is the only assembly that has a switch to indicate if the lap belt is buckled. I'm not positive on that. The switch in the buckle (the part with the release switch on it) may be defective. To figure out if the switch is defective shouldn't be to hard. Inspect the buckle to find the wire or wires going to it, should be two wires. You may have to unbolt the buckle from the floor or seat to find the wires. Follow the wire(s) till you find the connector, the connector maybe tucked under the carpet. Disconnect the it and use a small piece of wire to jumper the connector, not the connector that goes to the buckle, the other connector. If the bell sound goes away, the buckle needs to be replaced.
Feb 05, 2010 | 1998 Ford Windstar
Dead dryer no lights bells or indicators
no power to unit burned off neutral power wire on inside of unit,bad thermistor, defective control board
Oct 29, 2009 | Dryers
I have an old servant bell system how do i wire it in there is 8 push buttons in the house cant find any power source just bamboozled any help would be great reards paul
If there are lamps associated with the system, first find what voltage they are. Try to trace where the wiring goes to find if there is a source. It is even possible they ran the thing on old dry cells if it is very old. Some buzzers REQUIRE AC power, some will operate on DC. The power source WAS probably near the central indicator for the system.
Jul 27, 2009 | Electrical Supplies
Remote Weather Station shows "HHH"
This means that the read is over the HIGH limit of the sensor, perhaps is too hot there. Change it to another location. josemaX
Jul 30, 2007 | GE 75295 Clock Radio
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
