Question about Microsoft Xbox 360 Console
Tray not opening
Ok so i read about the tray not opening, but in my case i don't think is the belt because i hear it trying to open, but when i hit the top of it like on the middle part of tray if i hit the right spot, it will open up....what should i do?  I just baught it off ebay and the guy didn't mention anything about this..i'm still waiting for a response..please gimmee some advise..
Try tapping the disc tray, it worked for me, also if that doesnt work then try pushing it in and to the righ or left, dont press to hard though.
Posted on Nov 22, 2007
    Scholar:
  • 59 Answers
You should definitely contact the seller and since he did not mention a partially broken drive.  You could most likely get a partial refund for what you paid and in return buy another drive.  But before you go off spending your money you can take apart the drive yourself and look for anything that doesn't belong or is out of place.  The downside is that if you had a warranty it is now lost, and secondly 360's are a bit tough to get apart.  This is just a suggestion of what I would do.  Taking apart any electronics is always risky.  Good luck, i know what it feels like to have a partially busted xbox.
Posted on Oct 27, 2007
The tray is blocked. When I try to open it, I hear an ugly humming sound. The cd stuck inside can still be played. how can I open the blocked tray? I read that there is a emergency button under it, but I...
There is no easy quick release to the Drive Door. You have to take the cover off of the Player and in the front of t he drive tray there is a small motor that has a small belt on it. If that belt breaks of falls off of the pulleys, you will hear the motor spinning and then it gives up. You can remove a plastic plate over the motor and pulley and manually spin the drive gear to open the Draw and remove the Disc. The belt shuold be available online.
Jul 06, 2014 | NAD C541 CD Player
Cd or dvds trays wont open use paper clip can hear a response green lite appear but wont open
In this case there is something physically blocking it .probably if you press teh eject button and force it out in the same time with some kinda tool ..it will give up and open ..but will do the same ..when you close it ..So you have to take it out from the case and see if it opens once loose..if it does it means it was forced in the place and most of them does that when they are pressed in ..The only other cause may be a loose belt ..If you think there is no other way ..try to open it and see if there is anything obvious.....but..I suggest to change it if it does not open when you help it with a blade on the tray and pushing the button ..
Jan 01, 2012 | Gateway GT5220 PC Desktop
Opening and closing for insenrting a DVD,giving shocks from compo
I think in opening and closing the top case, you have either removed the earth connection or have let the top case metal part in touch with live wire.
Apr 20, 2010 | Cyberhome CH-DVD 300 DVD Player
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
Eject botton does not respond
there is a tiny drive belt connecting a small motor to the loading tray.when they stretch,they run but do not open the door.if that is the case,putting your ear on the machine while hitting the eject button will enable you to hear the loading motor running inside.if you do not hear anything,it is a different problem
Jul 13, 2009 | Philips DVP5140/37 DVD Player
Can't open dvd drawer
try putting a Blunt knife into the top of the dvd drawer, or where you can get a knife in.
And gently prise the drawer open whilst pressing eject on the Player.
Failing this, you will have to *****disconnect from the mains***** remove the screws on the rear of the casing, remove the top cover, and take out the DVD Disk.
Replace then plug back in, to check if the player is Ok.
**** Only remove the casing if you feel competant**** And if the player has no guarantee Or Warranty****
Mike @ Compurepair.
Jun 12, 2009 | Samsung DVD-P241 DVD Player
My Cyberhome DVR 1600 is dead.
If it is powering up it is NOT the power supply that is at fault. If the door won't open it is likely the belt that moves the tray.
Unplug the unit and remove the screws holding the case shut.
On the left side you will see a metal plate that is the top hold down for the DVDs.
Remove the four screws and pull up on the plate. There will be some resistance as the top spinner is held in place to the spindle by a magnet.
Plug in the unit but DO NOT touch anything on the right side where the power comes in!
Power on the unit and hit the eject button. If the tray slides out now you are partly in luck.
With the tray ejected unplug the power.
Partially push in the tray and look along the front. You will see a small pulley (motor) and a large pulley. There will be a "rubber band" looking drive belt there. Likely that drive belt is dry rotted.
Getting one is the trick. I'd suggest rescuing one from an old CD/DVD drive from a computer.
Dec 03, 2017 | Cyberhome DVR 1600 DVD Recorder
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
CD trays won't open
If it trying to open and moves part of the way I don't think it is a mechanical failure such as broken cogs in the gears or a belt if belt driven. Sounds more like there is something blocking it.
WITH THE UNIT UNPLUGGED!!!!
Without hitting the open button. use the "emergeny" open hole in the front. Use a paperclip or something to poke in the hole. Hopefully you feel a little resistance and it will pop open. If not...
Using a flashlight (I suggest a LED flashlight), using the above method, grab the tray when it opens slightly. Extremely gently pull the tray out at the same time looking for an obstruction around the tray. If you hit any resistance at all stop pulling, we don't want to further damage the unit.
To get a case off: MAKE SURE THE UNIT IS UNPLUGGED AND WAIT A FEW MINUTES SO THE POWER SUPPLY IS FULLY IS DSCHARGED. Follow the outline of the case removing any screws that hold the case to the chassis. Some have the full case come off, some just a panel. Remove the neccessary screws and poke around being careful not to touch any springs or such. Look for debris that doesn't belong..
Hold on, I just looked at the maual and there are 5 trays. Does this happen to all of them? If all, it is a different story. If each one is driven independently the power supply might be "weak" and not sending sufficient voltage/current to the motors. This requires a meter to check...
Jeff
Jan 11, 2008 | Sharp XL-MP130 CD Shelf System
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
Microsoft Xbox 360 Console Logo
23 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
