VIZIO M220VA HDMI HAS NO SIGNAL
WHEN I PLUG MY CABLE BOX OR PC INTO MY HDNMI JACKS THE SCREEN SAYS NO SIGNAL.
SOURCE: No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Posted on Aug 27, 2008
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
phongnv
  • 56 Answers
SOURCE: how to get digital signal without cable or convertible box
You can try to use the antenna for OTA signal. Use the connector labeled as DTV and then go to the main menu to scan for the channel.
Posted on Feb 16, 2009
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
My vizio is blinking back and forth from the blue no signal screen to the actual hdmi input screen which is connected to a cable box. What is going on?
Have you tried a different HDMI input? (If available.) You may be able to test the cable box of PS4 using component cables to confirm that all but the HDMI is not working. You may try pushing or holding the HDMI cables to see if you can make the problem better or worse to identify a possible flakey HDMI socket.
Jan 03, 2015 | Vizio 26 Class Edge Lit Razor LED LCD HDTV...
I plug my HP 2000 notebook into living room Vizio TV with HDMI cable, and no problems, the Vizio becomes the PC monitor. I plug into the bedroom TV (RCA) with same HDMI cable, and I get an UNSUPPORTED...
It's a resolution issue before you connect to your rca tv drop your resolution down on your computer and see if you can get a signal. When you connect the hdmi cable it should automatically adjust the resolution but sometimes it don't.
Thanks for your question sure hope it helps if not don't be afraid to ask for more help.
May 19, 2014 | Televison & Video
Vizio 22" m220va led lcd hdtv manual
Available here, under User Manual:http://www.vizio.com/m220va.html
Oct 02, 2011 | Televison & Video
Macbook Pro wont connect to Vizio tv
disconnect hdmi cable and shutdown pc, completely power it off. plug your hdmi cable back in to your pc and power it up. it should properly detect your tv. i use projector mode. tv must stay on while performing this procedure.
Feb 11, 2010 | Apple MacBook Pro Laptop Computer with...
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
