Question about Toshiba Office Equipment & Supplies
Crumpled paper e-studio 756 - Toshiba Office Equipment & Supplies
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: copiers
Odds are you have a small piece of paper blocking the paper path of the duplex or you have a clutch that is slipping.
Posted on May 07, 2013
Second copy is crumpled
You need to isolated a problem.Verify the vertical conveyance feed and clean the feed rollers,verify the fusing unit and a duplex unit,and verify the exit unit.Stop the copy process before the paper enter in the fusing unit,and verify if the paper is crumpled or not.If is crumpled verify the paper tray rollers(casette feed rollers,vertical transport rollers).If not crumpled stop the proces after a half copy is out on the fusing unit.If crumpled change or clean the upper and lower fuser roller and the lower roller cleaning roller(aluminium roller)in the fusing unit.
Dec 14, 2013 | Ricoh Aficio 2015 Black Toner Cartridge...
Crumpled paper
A bit more information is need ie model number and a description of where the paper us crumpling most crumpling problem are due to a foreign object like a paper clip stuck in the paper path
Nov 02, 2013 | Kyocera Office Equipment & Supplies
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
Copiers
May 06, 2013 | Toshiba Office Equipment & Supplies
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
Paper feed problem-wont go through- crumpling up as it tries to go through
You probably have a piece of paper stuck at the place where it's crumpling. Take a good look and carefully extract it. It may be small, so look hard.
May 01, 2009 | Office Equipment & Supplies
Drum is blinking
I found that buying good name brand paper solves the crumpling problem. Mine was doing the same thing and I was buying generic paper. I have switched to name brand and it has been working fine ever since.
May 17, 2008 | Brother HL 5250DN Laser Printer
Paper jam
If it is getting crumpled in the tray, there is something blocking the paper path.
What I would suggest is taking out the toner and drum cartridge, then remove the paper tray. Tip the machine on it's back and look into the paper feed area for something blocking the paper path.
When it is crumpling the paper like that, the feeder is working fine, just something blocking the paper path.
You can take a minela folder, and gently push it through the paper path to dislodge the obstruction.
Mar 31, 2008 | Sharp AL 1631 Copier
HP PSC1410 All in one
crumpled papers are due to something stuck inside, or the rollers are dirty, causing a misfeed
new print drivers are sometimes needed after fixya this sort of issue. get em here
Mar 23, 2008 | Office Equipment & Supplies
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
