Question about Meru networks ap 200 access point ap200warranty: 30 day warra
Cabling antenna distance from AP200 - Meru networks ap 200 access point ap200warranty: 30 day warra
  • Meru Master
  • 3,320 Answers
No more than 200 feet
Posted on Mar 20, 2014
I have a tobshiba theater view HD tv. Model number is 55h70 and I bought an antenna and I can get any channels.
When you set up the tuner, change it from cable to air, digital channels only. Then do a channel search. Antenna orientation is critical and the distance from the TV station to the antenna will determine the size of the antenna.
Apr 16, 2017 | Televison & Video
I have a Hisense TV and am trying every antenna to get local channels but it searches and finds no channels... Frustrated... I don't have cable or wifi any suggestions?
You need to find out the miles between the t.v. and the nearest broadcast antennae. Call a few t.v. stations. Then buy the proper distance antennae with outdoor attachment for window.
Hope that helps.
Oct 24, 2016 | Hisense Televison & Video
Not working
Some laptops may have a direct input for the Wifi antenna......you have to check with the manufacturer of the laptop if you dont see an input jack for an antenna. Usually those antennas are built into the laptop internally.
Mar 21, 2014 | Ideaworks Long Distance WiFi Antenna
How do I get local channels without having to get cable or satellite tv
Connect an antenna to your television. The type and size of the antenna will depend on the frequencies used in your country and your distance from the transmitters.
Jul 28, 2012 | Samsung Televison & Video
I am installing a Terk FDTVO antenna. Should the preamp be located closer to to antenna or the tv?
Whichever works better. It depends on the distance between the broadcast antenna and you as well as the distance of the ant cable and the type of cable you ran. Trial and error, no expert science to it. I have installed many without the amp at all. best of luck!
Jul 07, 2011 | Televison & Video
From a point on the ground, a person notices a 110-foot antenna on the top of a hill subtends an angle of 1.5 deg. If the angle of elevation on the bottom of the antenna is 25 deg, find the height of the...
Draw one right-angle triangle:
D
C
A===B
A = your location
B = bottom of the hill
C = bottom of the antenna
D = top of the antenna
The A-B distance is constant.
The B-C distance is unknown.
The B-C-D distance is unknown.
The C-D distance is given.
The C-A-B angle is given as 25 degrees.
The D-A-C angle is given as 1.5 degrees.
Use SINE and COSINE functions to determine the B-C distance.
Tell your teacher that you found the answer to your homework on the Internet.
Sep 24, 2010 | Computers & Internet
Kdl-37w55/57 sony bravia problem is every so often the picture seems to stutter,delay best way to describe it. Any ideas
hello, try tightening your antenna connection this happens when your signal input cable is fualty or loose check that first. then try all other connection that come from your cable,sat reciever or antenna hook up. if your using a digital reception device or digital antenna check those connections to. and be aware that digital reception has interuptions and they depend on the distance between you and the digital signal broadcast station, sometimes storms and atmospheric conditions may cuase a brief lapse in the signal.(stutter) what are you using for a reception? satelite, cable or a digital antenna? hope this helps
Jun 04, 2010 | Sony Televison & Video
I use an opoen air antenna,this morning i could get channels 4,5,9,11,13,19,27,29,38,41,49,50,abruptly i lost all channels but 11,27,49 which are local tv stations,does my tv have two signal tuners,one for...
Digital TV come and goes. Strength varies and you may find interferance can be an issue. The trees a new building. You may have to optimize your antenna or even purchase an amplifier for the signal from the antenna. Ask your nieghbors with similair systems if they are having trouble.
Don't count out a bad cable or antenna failure
Apr 12, 2010 | Televison & Video
I use that router to connect to outside grid antenna.Tall me if is possible.
It certainly is possible, as the WAP54g has detatchable antennas, but keep in mind that 2.4Ghz cables are both very expensive and very lossy, so you'll want the WAP54g to be as close to the external antenna as possible.
Typical outdoor installations have a weatherproof box mounted with the antenna, to keep the cable length to less than 12 inches. You have to run power and ethernet to the enclosure, but neither of those have loss issues over distances of less than 100M (roughly 300 feet)
Sep 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Compaq AP200
No Beeps?
Could be several things - Re-seat the ram
Could be the power supply, could be the video adapter.
Could be the monitor. Is there any more info you could give. Does the monitor say out of frequency, by chance?
I would assume the video adapter is on-board. Could u try another video adapter in a PCI slot?
Sorry, I will just need some more info to be able to help.
Oct 24, 2008 | Compaq Professional AP200 PC Desktop
Meru networks ap 200 access point ap200warranty: 30 day warra Logo
Top Meru Computers & Internet Experts
David Payne
David Payne
Are you a Meru Computer and Internet Expert? Answer questions, earn points and help others
