Question about Eric MacKinnon Travel Brain
Server refused connection!!!! - Eric MacKinnon Travel Brain
Minecraft
Is it legitimate copy of Minecraft? And if so then it's probably just server problems at the moment that will resolve eventually in due time.
May 24, 2013 | E-Machines eMachines Desktop PC
The Proxy server is refusing connection,. Unable to connect to the Proxy server. Error 130 (net : Error_Proxy_Connection_Failed)
Google Chrome may not be using a proxy from your ISP odds are that it is not so you will have to go into the tools and options and then select connections section and disable the connection for proxy server usage just un check it not to use any proxy servers that is what is going on. I hope that this assisted you. Thanks for using FixYa! John
Apr 13, 2011 | Google Chrome
The proxy server is refusing connections
When you set up your internet connection, you apparently entered information about a proxy server. Go back through that procedure and delete the reference to proxy server. Hope that helps!
Mar 19, 2010 | Toshiba Equium 6200M (PV1026U-01A) PC...
How do I fix "Http service unavailable" message?
10.5.4 503 Service Unavailable The server is currently unable to handle the request due to a temporary overloading or maintenance of the server. The implication is that this is a temporary condition which will be alleviated after some delay.
Some servers may wish to simply refuse the connection.
This not something you can fix, but rather, it can only be handled by the website you are trying to reach.
Oct 14, 2009 | Microsoft Internet Explorer 7
Network error IOException: Connection refused: connect
Please check that you are on the same sub net and that your network setting correspond to those required by the server including matching access passwords etc.
Aug 19, 2009 | Microsoft SQL Server 2000 Standard Edition...
Firefox refuses connection with ultrasurf's proxy
Well Ultrasurf obviously does not want to work with your internet connection (like mine)
For now you need to remove Ultrasurf. Go to Tools>>Add-ons>>UltraSurf Firefox Tool>>Disable OR Uninstall.
That should at least get your internet working...
As for a working proxy, try using a "Web based proxy"
Google it.
Thanks,
Ted
Mar 17, 2009 | Toshiba Equium 6200M (PV1026U-01A) PC...
Proxy Server Refused Connection Firefox is configured to use a proxy server that is refusing connections. ...
If you're using Firefox, click on "Tools" at the top of the page, click on "Options" which is at the bottom of the list that comes up, then click Advanced, choose Network from the four tabs below that. There should be a sentence "configure how Firefox connects to the Internet". Click on the button next to it that says "settings". and make sure that "Auto-detect proxy settings for this network" has a dot in the little circle. If not, click on it and click on OK.
You may have to shut down Firefox (your internet browser programme), then try getting in again. Should have sorted it.
Nov 29, 2008 | Computers & Internet
Eric MacKinnon Travel Brain Logo
373 people viewed this question
Top Eric MacKinnon Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you an Eric MacKinnon Facebook App Expert? Answer questions, earn points and help others
