Why do I have a number 2 and flashing cursor with a black screen on windows vista when I try to boot?
    Master:
  • 965 Answers
It may be telling you that it is set up for monitor 2
the
Posted on May 29, 2014
Benimur
  • 6966 Answers
SOURCE: acer aspire 5920-6864 wont boot up
Hi and welcome to FixYa,
Initially, try:
  • "Press F2 to Enter System Configuration Utility";
  • determine if the hard disk could be detected by the CMOS/BIOS;
  • if yes, possibly corrupt partition would need re-partition/re-format and re-installation of Vista;
  • if no, possible faulty hard drive and would require replacement.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 09, 2009
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
  • 59 Answers
SOURCE: My Toshiba Satellite a205-s5814 turns
it looks like windows is corrupt or your hard drive is faulty. if you have a recovery disc try using it to repair wondows. if that doesn't work you might need to do a clean install which means you'll lose your documents. if that still doesn't work it's likely to be your hard drive. even if you run a check disc on your hard drive and it passes that doesn't mean there isn't a fault with it
Posted on Jan 15, 2011
aaarwind
  • 141 Answers
SOURCE: old rm cl51-15 laptop wont boot to windows - does
i suspect the problem with the RAM .
Go to memtest.org.
Download any version of "Memtest86+". and burn the image to CD or make USB boot
and boot from that CD or USB
If the software shows any problem in RAM then replace the RAM. best of luck.
Posted on Jan 19, 2011
  • 87 Answers
SOURCE: i have a ASUS k52j
you should try to boot your notebook from a windows CD and use the automatic repair to fix the problem. In case that doesn't work, you might need to format and reinstall windwos. In case you need to recover any data, you can use a linux-based live distro (you can find one here http://www.livecdlist.com/) to backup them on an external drive.
Hope it helped,
Franz
Posted on Mar 02, 2011
Why do I have a number 2 and flashing cursor with a black screen on windows vista when I try to boot in a Lenovo laptop?
Bad hard drive 90 percent of all computers is HARD DRIVE related. Virus ate the boot sector, partition is damaged or scatched, to many files and the pagefile is on manual, hard drive failure due to age period, 90 percent of all computer failures is Hard Drive related.
Feb 13, 2014 | Computers & Internet
What does it mean when I boot up and I get a number 2 with a flashing cursor on a black screen for windows vista?
1) Reboot, then when it is starting up, press F8.
2) Click "Repair my computer".
3) Select the keyboard layout and lanugage.
4) When you get to system recovery tools, select System restore.
5) Select the restore point when it was working fine and restart the computer.
6) Best of luck!
Feb 13, 2014 | Dell Optiplex 755 Energy Smart Minitower ...
Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to...
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
May 19, 2011 | Computers & Internet
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3...
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
When I try to boot up windows Vista I get black screen
Looks like its an infection to me.
When you get to the black screen and you are able to move the mouse, try this:
Press Ctr+Alt+Del, a message will pop up.
Select Task Manager
A Task Manager window appears.
Click on File and choose New task (run)
Type: explorer.exe
Press the enter key.
You should be able to see your desktop again.
Once there, use a combination of antivirus, spyware, troyan horses solution of your preference to get rid of it.
Don't forget to rate this answer if it helps
Dec 04, 2009 | Acer Aspire 5610-4648 Notebook
I have a DV9000 whos screen goes black immed after power up
try to press F8 continuously before the microsoft image until you get different options. select "Safe Mode" on the options using your UP or DOWN cursor keys then hit ENTER. if it works and boots up then you can use the windows operating system disc to repair it. if it still does the same thing then you might need to reformat and reinstall the windows vista operating system...
Nov 08, 2009 | HP Pavilion dv9000z Notebook
Vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Mar 25, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
