Question about Ford "c" Cabover Semi Tractor-disalvo Trucking - White
Won,t shift in cold morning - Ford "c" Cabover Semi Tractor-disalvo Trucking - White
Transmission wont shift
The fluid is had it basicly you need to change the transmission fluid.
Have you checked the fluid level recently when cold first thing in the morning.
Sep 19, 2014 | Cars & Trucks
My 1997 plymouth grand voyager se won't shift out of park
Check your brake lights, if they don't work you can't shift out of park
Sep 16, 2014 | 1997 Plymouth Grand Voyager
1994 chev 1500 won't shift past 2nd when cold
Try the solenoids that control the shifting. May need to replace them.
Dec 22, 2012 | 1992 Chevrolet C1500
Won't start easily since it got cold (32degrees). It's fine once it starts
Its cold start issues:----
Go through the list of help links mentioned below:----
Click the link :----
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
Ford explorer 4.0 will not idle when cold?
http://technoanswers.blogspot.in/2012/02/ford-explorer-40-will-not-idle-when.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These will help.
Thanks.
Dec 14, 2012 | 2004 Dodge Ram 3500 Truck
My 1980 mgb overdrive shifts fine cold when it reaches operating temp.it won't shift up or down.
Solenoid coil warms up and dissipates too much voltage with age and needs replacing. Bottom of overdrive unit. Sometimes cleaning and adjusting can help extend their life a bit.
Nov 12, 2012 | Cars & Trucks
2007 HHr auto transmission won't shift properly
Check the auto fluid level when cold. The level increase when warm. with any luck its just low fluid.
Jun 28, 2012 | Chevrolet HHR Cars & Trucks
1990 4runner not shifting properly when cold.
hello, first you need to make sure the engine gets to operating temperature, maybe the thermostat needs to be replaced, if after that it still has the same problem the temp sender could be the issue here. It is located on a housing in between the cylinder heads near the firewall where the heater hose connects. there are two temp sensors, one for the gauge on the dash and one for the computer.
The dash sensor has a single wire, the computer temp sensor has a connector with two wires and is a green connector.
Dec 15, 2017 | 1990 Toyota 4Runner
Car won't start on cold mornings.
Get an new battery and make it one with more AMPS than you have now.
Nov 17, 2011 | 1997 Jeep Cherokee
My 2002 pontiac montana trans has trouble shifting in cold weather. It is a overdrive trans. it will shift from low to second and sometimes one more time. I can drive it slow after a little bit it will...
You may have a case of morning sickness. in a transmission they are seals the are bad and leak fluid past them. causing a shifting problem when cold as fluid warms up seals swell and your pressures increase allowing a better shift.
Feb 11, 2011 | 2002 Pontiac Montana
When cold in mornings when back up then shift into
Every car needs a heating engine time specially when its cold, I recomend like about 5 to 10 minutes after you start engine and before you change from P to D. If you try to start the engine first time in the morning, it's cold outside and you immediately go on run you are going to have this trouble every time. Every engine has it's operational standard temperature a 5 to 10 minutes working engine, car stopped, may guaranty this standard temperature and optimal function conditions, and also keeps a longer life of your car.
Good luck
May 07, 2010 | 2003 BMW 5 Series
Ford "c" Cabover Semi Tractor-disalvo Trucking - White Logo
27 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
