Question about Dell Optiplex 755 Energy Smart Minitower Intel Pentium Dual Core Processor E2160
What does it mean when I boot up and I get a number 2 with a flashing cursor on a black screen for windows vista?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
1) Reboot, then when it is starting up, press F8.
2) Click "Repair my computer".
3) Select the keyboard layout and lanugage.
4) When you get to system recovery tools, select System restore.
5) Select the restore point when it was working fine and restart the computer.
6) Best of luck!
Posted on Feb 18, 2014
4 Suggested Answers
  • 35 Answers
SOURCE: MY optiplex gx280 intermittant boots correctly
It sounds like a problem with the boot loader inside of windows. If you are getting no errors then this is most likly the case.
The following link shows you how to get to the recovery console.
http://support.microsoft.com/kb/314058
from there you need to run 2 commands. the first is: fixboot
the second is: fixmbr
Just type those in when you get to the command line. if that fails, you need to reinstall windows. either way, back up data...ie songs, pictures, documents...etc.
Posted on Feb 10, 2010
  • 52 Answers
SOURCE: Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Posted on Apr 19, 2010
philmik
  • 107 Answers
SOURCE: I have a Dell desktop running Windows Vista. I
Some times you have such an error when you leave USB Flash Drive or External drive connected. Try first to disconnect all external USB devices if you have some.
Posted on Feb 02, 2011
Why do I have a number 2 and flashing cursor with a black screen on windows vista when I try to boot in a Lenovo laptop?
Bad hard drive 90 percent of all computers is HARD DRIVE related. Virus ate the boot sector, partition is damaged or scatched, to many files and the pagefile is on manual, hard drive failure due to age period, 90 percent of all computer failures is Hard Drive related.
Feb 13, 2014 | Computers & Internet
Dell latitue D610 stuck on black screen with a blinking cursore.. help?
First, try and boot into safe mode by powering off your computer then powering it back on and tapping the f8 key, after that you should see safe mode and other options below it, click the first option which is safe mode, then go into your start menu and go to your system restore which in Windows 7 and Vista is located in accessories and then system tools, then choose a restore point earlier than the date you are on. This is a temporary fix and you will need to get a virus removal done asap. Hope this helps.
Live Technical Support
My Youtube Channel
Mar 24, 2013 | Dell Latitude D610 Notebook
Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to...
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
May 19, 2011 | Computers & Internet
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3...
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
My asus p5vdc-x flashes the asus motherboard screen, beeps once, and then goes to an all black screen with a blinking cursor and doesn't boot up vista. It worked fine yesterday, when I started it up and I...
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Dec 02, 2010 | ASUS P5VDC-X Motherboard
Vista boots just Black screen with cursor even in safe mode
Yes, this is a known issue with Vista. You need to back-up your data, format your hard drive and re-install Vista from the beginning.
There is really no use trying to repair it: it is damaged.
After you re-install Vista, do not forget to install service packs from microsoft.com.
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Mar 25, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Dell Optiplex 755 Energy Smart Minitower  Intel Pentium Dual Core Processor E2160  Logo
Alun Cox
