Question about Reebok Vista Treadmill - RBTL13305
Board lights up but motot does not work. power seems to be going to motor
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
C.T.M HS320 power chair wont go with full charge and all connections,fuses good.
Could be in Lock Mode. Don't know your controller type but VSI Profile LEDs will scroll from left to right when in a lock mode. Identify your controller and get lock/unlock instructions.
Mar 08, 2013 | Ctm HS-2800 Power Wheelchair
Wipers workbut the spray does not.i have replaced the small motor no help.
Most vehicles have a circuit board in the wiper motor that fails from time to time. You will need to check for power at the washer pump, If no power there, check the wiper motot circuit board, Good luck, Gary
Jul 26, 2010 | Cars & Trucks
Belt stop working. All lights lit.
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
May 16, 2010 | Nordic Track /proform Treadmill...
Carosel doesnt turn on rowe ami r-82 jukebox
First check to make sure you are getting power to the drive system. If turntable is belt driven, check power to drive motor, then check the belt. Otherwise it is direct drive, which means the turntable is connected directly to ths motor and the motot will have to be replaced.
May 16, 2010 | Audio Players & Recorders
Cooker hood motor failure lights work extractor motor just hums no movement is it brushes in motot ?
probably gummed up from oil and grease if u have access to the motor use a spray lube and spray the shaft as it goes into the motor case this should free up the bearings -if no access remove motor clean than oil up motor turn motor back and forth by hand and will free up replace and test
Feb 10, 2010 | CDA Cooktops
Hvac blower motor doesn't work ,where is the motot located and what does it look like
the blower motor is located under the glove box ,you will see a panel under the glove box you will have to remove 4 or 5 screws will have to be removed.you can use a phillips screwdriver or a 5/16 socket,the blower motor is round about 5" diameter..unhook the wires and test to see if you have power to it(make sure you have the key on and the fan control on,if you have power there then your blower is bad,
Dec 11, 2009 | 2001 Oldsmobile Alero
Same problem on my pos. i pulled the inside rear cover off in the
i would first make sure the wires going to motor are nice and tight if, then i would use4 a meter at the motor if you get a constant 110 volts to motor motor may be defective if voltage comes and goes with meter hooked up to motot then bad board.
Sep 23, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Hoover power drive u6311 - How do u change switch? Does anyone have any idea how to remove the on and off switch, when I tap on the housing the motot and light goes on and off. Also does somebody have a...
The swrtch is located in the bottom section of the motor. When the swtcih goes out it time to repalce the unit. The swtich is part of the motor. The switch rod run all the way down the body to the swtich located in the motor.
May 23, 2009 | Hoover U6311-930 Power Drive Bagged...
Reebok Vista Treadmill - RBTL13305 Logo
49 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
