Question about Pool & Spa
8.50g of potassium combine with 7.71g of chlorine to form potassium chloride. What is the percent by mass of chlorine in potassium chloride
8.50g of potassium combine with 7.71g of chloride to form potassium chloride, what is the percent by mass of chlorine in potassium chloride
3 Suggested Answers
  • 55 Answers
SOURCE: How much potassium chloride has to be dissolved in
Not sure making C4 should be outlined here.
Posted on Sep 19, 2013
  • 46 Answers
SOURCE: Please break down into 1 teaspoon of salt the mg of potassium bicarbonate and magnesium chloride. Thank you so much.
5 687.50 milligrams
Posted on Oct 08, 2014
The Zodiac Chlorinator problem showing on the system is 'low in salt' and yet we have added 8 of 25 kg bags only 7 days ago Our pool has 50,000 litres of water
Most salt water chlorination systems have their sensors in the cell. This is the unit that the water passes through to convert sodium chloride into chlorine. If the cell hasn't been cleaned recently that would be the first step to try. Cell cleaners are available at most pool supply stores. Short of that you may need to replace the cell itself. I would also contact Zodiac directly online to get support there.
Sep 08, 2017 | Zodiac Pool & Spa
Tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
on May 17, 2011 | Water Dispensing & Filtration
Who shall take Potassium chloride?
Potassium Chloride (KCl) is used as a No Sodium Salt alternative to regular Salt which is Sodium Chloride (NaCl). The people who take it are people who want to reduce their sodium intake, commonly people with high blood pressure. If you are planning to use it for cooking be sure to reduce the amount you use and to taste as you apply it because KCl actually tastes saltier than NaCl.
Jan 10, 2017 | Cooking
Is menudo bad for you?
this soup isn't very high in nutrients, although it does contain 4 to 5 percent of the daily value for iron, vitamin A, potassium and phosphorus in each serving. You need iron for forming red blood cells, vitamin A for healthy vision, potassium for counteracting the blood-pressure raising effect of sodium and phosphorus for forming strong bones. The only vitamin or mineral typically found in large amounts in menudo is sodium, which you want to limit in your diet. Each 1-cup serving of menudo contains 971 milligrams, or 40 percent of the DV for sodium.
Sep 01, 2014 | Miscellaneous
Not getting biger crystals of potassium chloride
Bigger crystals will crystallized from purest material. You may be have purify KCl, use pure and filtered before using water/solvent, protect beaker or used vessel from air dust.
Jan 01, 2014 | International Crystal Labs 0002B-115 -...
What minerals are found in apples?
Apple Calcium Copper Iron Magnesium Manganese Phosphorus Potassium Selenium Sodium Zinc
Jan 17, 2013 | Cooking
By using regularly it ,i am getting some pimples ,alergy.
I am not sure what type of skin you have, if it is oily, dry, or combination. I have heard that it works the least with combination skin. Have you had any reaction from any other type of face wash?
Here are the ingredients in case you might know of something you react to.
Aqua / water, Palmitic acid, Myristic acid, Lauric acid, Potassium hydroxide, Stearic acid, Peg-7 glyceryl cocoate, Sodium cocoamphoacetate, Disodium laureth sulfosuccinate, Peg-150 Distearate, Glycerin, Ascorbyl glucoside. Alcohol, Dmdm hydantoin, Limonene, Linalool, Benzyl salcylate, Gentiana lutea / gentiana lutea extract, Propylparaben, Disodium edta, Butylparaben, Cetyl hydroxyethycellulose, Citrus limonum / lemon fruit extract, Bht, Parfum / fragrance, Sodium chloride.
Hope this helps!
Sep 19, 2011 | Garnier Light Fairness Face Wash 50 g Pack...
After bonding atoms we are ask to name the resulting compounds in its common name and as well as its chemical name. so my question is, what is the difference between common names and chemical names? please...
Common name is the name what people call it, it usually gives you no idea as to what the chemical composition of the compound is. (eg: Common name for Sodium Chloride is Salt) whereas the chemical name is based on what the compound is made up of (A molecule of salt is made up of one atom of Sodium and one atom of chlorine. this can be understood from the chemical name, but not from the common name.)
Mar 08, 2011 | Computers & Internet
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
54 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
