Question about HEWLETT-PACKARD 6500A Plus InkJet Printer
Wont fax Has dialtone but wont fax
Can receive faxes but can't send them
did someone reverse the line cord to "telephone"? Do you have a dialtone when using monitor
Apr 04, 2014 | Ricoh 3320L Laser Fax
Intellifax 4750e phone and fax line stays open, no dial tone
Is the fax machine on? (Are the lights or screen lit up?) Make sure that the line going from the fax machine to the wall jack is plugged into the LINE port on the fax machine, and not the TEL port.
Try plugging a regular phone into the wall jack where the fax machine is currently plugged in... do you get a dialtone? If so, the problem is either with the fax machine or the way it is configured.
May 27, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
I have no dial tone on my fax machine and i cant send or receive faxes
Remove the phone line from the back of the fax and connect a standard phone (not a business PABX or PAX system phone) to the line. Ensure dialtone is available. (Make sure in doing this that you are also testing the cable from the phone socket to the fax). If no dialtone, replace cable or fix line.
Check that the line is connected to the 'line' port on the fax, not the 'phone' port.
If still no dial tone, it may be modem fault (in the fax). Seek specialist attention.
Feb 12, 2010 | HP 640 Inkjet Fax Machine
No dial tone
plug out the fax... plug in a phone... if still no dialtone... replace phone cable... still no dial tone... call the phone company...
plug out the fax... plug in phone... dial tone heard... bad fax... try to reset fax machine... per instructions... still no dial tone... call repair guy...
Dec 18, 2009 | Office Equipment & Supplies
Fax has stopped working on Gestenter DSC525
The modem card is faulty. It needs to be replaced.
Aug 11, 2009 | Gestetner DSc525 All-In-One Laser Printer
No dail tone on my fax sending screen. But there is dialtone in my telephone
Make sure the connnection is securely inserted on both end. If it is try new phone line from the modem to the jack on the wall.
May 24, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
Lexmark 5600 series 4in one fax dial problem
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted.......
U will be able to send and recieve faxes.....
Thanku.............
If still the same problem contact your telephone Compny
Jan 12, 2009 | Lexmark X5470 All-In-One InkJet Printer
Not able to fax due to no dialtone?
Check the phone line with a regular phone and listen for a dial-tone.
Jan 06, 2009 | Lexmark X2350 All-In-One InkJet Printer
Faxempfang sowie faxe versenden funktioniert nicht mehr
Can you be more specific? What error code is the fax machine giving you? Do you get a dialtone if you pick up the handset?
What is your fax machine make and model?
Jul 07, 2008 | Samsung CLX-3160 All-In-One Laser Printer
HEWLETT-PACKARD 6500A Plus InkJet Printer Logo
10 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Omer M. Elhag
Level 1 Expert
Mark Schmit
Mark Schmit
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
