Question about Xerox WorkCentre 5150/PH Printer
NOISE clicking noise inside the machine
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Xerox Expert
  • 111 Answers
May be from fuser
Posted on Mar 19, 2016
We have a brother fax machine and it makes a loud clicking noise we think the brushes are broke
There may be several reasons for the clicking noise
1. May be paper clips or other foreign material got stuck inside
2. May be a piece of paper got stuck inside and is somewhat causing this problem
3. May be after having removed a paper jam, some parts within the machine got loose.
The most evident situation is to have a quick look, without disassembling the equipment.
If still the problem persists, then it's better to have the equipment checked by a professional.
Mar 31, 2010 | Brother IntelliFax-4100e Fax
Making a noise when spinning like there a coin inside
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hdgket
Nov 29, 2009 | Candy CNW136 Front Load Washer/Dryer
Click and clunk when moving from right rear wheel Pride Elite +
This can be caused by two things usually. One cause is the bolt holding wheel to the axle is a little loose so check to make sure it is very tight on the axle. The second click comes from flat-free tires. The tires have an adhesive applied at the factory and if you hit a bump, or if there's not enough to hold the tire tight to the rim, the tire will make a grinding click noise when it rolls and passes over this area. Pneumatic tires properly inflated don't make this noise since the air pressure keeps the tire fixed to the rim at the bead; flat free tires lack this pressure. Simply lubricate the area around the tire where it meets the rim on inside and outside, and drive it...noise should dissipate.
Aug 28, 2009 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Adutator not working well,and cliking noise while adjutating
pop up top off the agatator,pull the inside cap out,there are 4 dog ear gears in there that have to be replaced,your local appliance parts store has them for $mike
May 08, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore 98702 Stacked Washer/Dryer. Dryer making clicking noise
There may be coins stuck inside the tumbling vanes in the drum.
Mar 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Noise from washing machine
heatman101
fddfs
Oct 25, 2008 | Whirlpool AWG329 Front Load Washer/Dryer
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Xerox WorkCentre 5150/PH Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
