Question about Dryers
Kenmore Quiet Pak 2 dryer wont start.
We've had problems this winter with our dryer only running when the start button is held. I determined that it was due to the extreme cold. I could blow a hair dryer into the bottom access and after a few minutes it would work properly. Now today, it won't work at all. The outlet is good (I checked it). All I get is a click in the power control when I push the button. Is this likely the thermal fuse?
  • Dryers Master
  • 2,694 Answers
What's the model number if you have a dryer with even heat and it will say it on the top console most likely you have a bad even heat board located in the top console,also there's a motor and heat relay in there that could be bad but usually it's the even heat board.go here
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
hope this helps
Posted on Feb 13, 2014
  • 4 more comments
  • Rob Davis
    Rob Davis Feb 13, 2014
    Thanks to ALL of you who have replied so far!!!!
  • Rob Davis
    After reading all of your replies, I decided to go with the easiest and cheapest approach first....which was Sal DeAngelo's post. First off, I have to say....this dryer is a PAIN to work on!!! Although I could see (and test) the thermal fuse as soon as I took the front panel off, I couldn't get to it to remove it, without completely disassembling the dryer, and removing the drum! I'd seen someone say that if you replace the fuse, you should also replace the thermistor. So, after the big project of taking everything apart, I took those two things to the local appliance repair shop. They had the fuse in stock. But I have to wait until tomorrow for the thermistor. I will post again, after reassembling everything, and testing. Thanks again, for all of the replies.
  • Sal De Feb 13, 2014
    rob open the door to the dryer,look around the opening where you put the clothes in,you'll see a tag with the model and serial number,if you send the model number i can look up your dryer and see what parts are in it and i can help you out better.
    also rob depending on what model you have if you remove the duct that the lint filter slides into you can get to the thermal fuse with a 1/4 inch socket and ratchet but if the thermal fuse pops it won't work again it's nonresetable,if you look at the picture that's on the site i sent to you the heater relay and motor relay are the same part,take a picture of the wires or draw a picture of where the wires go and switch the relays,if it starts after you switch them you know the relay is bad without buying anything but you won't have any heat because the bad relay will be for the heat,if the relay is good it will be the even heat board if you hold the start button in and it will run and if you let it go the dryer will stop.bad board.
  • Sal De Feb 15, 2014
    if you need a tech to come out and you live in ma. call peter de's appliance 781-438-9442
  • Sal De Feb 21, 2014
    did you fix your dryer?
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Posted on Mar 28, 2009
  • 1028 Answers
SOURCE: Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Posted on Aug 04, 2008
  • 2694 Answers
SOURCE: Kenmore Dryer-90 Series- Pushed Start button nothing happened
get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
Posted on Mar 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite heavy duty king size quiet pak 1
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^&
I have a quiet pak 2 Kenmore. When I depress the start button the drum works but there is no heat. I stops workin when I take my finger off the start button. Model 110.73932102
I looked up the model number. You have a 90 series dryer made by whirlpool. You need to take it apart and clean it up, cheack all limits and safetys for continuity. I beleive you have a bad motor If the drum turns and the belt is not broken when you release you button it stops that is either the start switch or the motor.
Feb 05, 2014 | Kenmore Dryers
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite Heavy Duty King Size capacity Quiet Pak gas dryer. The model # is 110.76922501 and the Ser # is MTO502806. The problem I am having is that the dryer sometimes does not start when...
the push to start switch holding coil is getting weak and can no longer either make contact or drop out shutting down the unit,there is a coil that energizes to hold the switch on and when the contacts or coil get weak the unit either wont start or start and drop out/quit,you can test this switch by bypassing it and if unit keeps running the switch is definitely bad then the unit is a whirlpool produced for kenmore by the 110# you provided so you need to order a switch either thru whirlpool or sears
Aug 22, 2011 | Kenmore Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore elite quiet pak II will come on when the start button is pushed, but as soon as I let go, the dryer goes off---HELP!
this is the answer:
Nov 27, 2010 | Dryers
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer doesn't work when I want it to
do you mean you changed out the dryer and the same thing is happening?if so it's not the dryer,either your vent line is clogged with lint and the dryer is cutting out from over heating and coming back on when it cools down or you have an electrical problem because there is no way your gonna have that same problem on two dryers,try running it with the vent line removed from the back of the dryer let me know about this
Nov 04, 2009 | Kenmore Dryers
Dryers Logo
74 people viewed this question
Top Dryers Experts
