Question about Dryers
Quiet Pak 2 dryer
We've had problems this winter with our dryer only running when the start button is held. I determined that it was due to the extreme cold. I could blow a hair dryer into the bottom access and after a few minutes it would work properly. Now today, it won't work at all. The outlet is good (I checked it). All I get is a click in the power control when I push the button. Is this likely the thermal fuse?
  • 2669 Answers
SOURCE: Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Posted on Nov 19, 2009
  • 3 Answers
SOURCE: No power to selector panel
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
Posted on Feb 17, 2010
  • 523 Answers
SOURCE: Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
Posted on Jun 08, 2010
  • 10865 Answers
SOURCE: I have a Maytag MED9600SQ0 electric dryer that
Hello. There are only 4 possible problem areas to check when it will not start:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Aug 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite heavy duty king size quiet pak 1
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^&
Posted on Sep 30, 2010
Kenmore Quiet Pak 2 dryer wont start.
what's the model number if you have a dryer with even heat and it will say it on the top console most likely you have a bad even heat board located in the top console,also there's a motor and heat relay in there that could be bad but usually it's the even heat board.go here
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
hope this helps
Feb 13, 2014 | Dryers
I have a quiet pak 2 Kenmore. When I depress the start button the drum works but there is no heat. I stops workin when I take my finger off the start button. Model 110.73932102
I looked up the model number. You have a 90 series dryer made by whirlpool. You need to take it apart and clean it up, cheack all limits and safetys for continuity. I beleive you have a bad motor If the drum turns and the belt is not broken when you release you button it stops that is either the start switch or the motor.
Feb 05, 2014 | Kenmore Dryers
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite King size Quiet Pak II dryer that won't stay on unless i hold the button down and even when i do that the dryer is not getting hot.. Any suggestions would be...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Dryers
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore elite quiet pak II will come on when the start button is pushed, but as soon as I let go, the dryer goes off---HELP!
this is the answer:
Nov 27, 2010 | Dryers
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer doesn't work when I want it to
do you mean you changed out the dryer and the same thing is happening?if so it's not the dryer,either your vent line is clogged with lint and the dryer is cutting out from over heating and coming back on when it cools down or you have an electrical problem because there is no way your gonna have that same problem on two dryers,try running it with the vent line removed from the back of the dryer let me know about this
Nov 04, 2009 | Kenmore Dryers
Dryers Logo
21 people viewed this question
Top Dryers Experts
