Pc want power up
Dell 530inspirin press power wont start green light on the back amber on motherboard
    Sergeant:
  • 446 Answers
Change the power supply
Posted on Mar 09, 2014
SOURCE: 4600C no power, flashing amber light
The problem is with your microwave. The Dell PC on boot has detected the radiowaves. This has in turn when booting the Dell put it in to Ultra Safe Mode. This is new to this model Dell- the advantage is that you can still cook your ready made meal with out damaging the system board capacitors. Once the micro wave has finished you will be able to boot - dont forget it may be your neighbours micro wave!!
Posted on Apr 09, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
proton77
  • 1183 Answers
SOURCE: Dell 2400 PC- blinking amber light.
Hi Sherri,
The symptom that you are facing generally refers to bad power supply. The same can be resolved by replacing the same. You can call dell sales to procure a new power supply. However to troubleshoot and make sure if power supply has gone bad , use the link below
http://tinyurl.com/6ezjbp
Thanks
proton
Posted on Nov 03, 2008
  • 8 Answers
SOURCE: dell dimension 8100 diagnostic lights
Green Green Green amber is a start of "POV" whatever this stands for. Dells description is "System activity subsequent to video initalization" I would start with video card replacement,
Posted on Jan 09, 2009
ajx13
  • 110 Answers
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Posted on Aug 11, 2009
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Computer shut down continuously during start up...dell
If you've cleaned it internally make sure there are no loose connections you've knocked. Esp where the Hard drive is connected to the motherboard.
Oct 20, 2012 | Dell Computers & Internet
Dell desktop 4700 problem
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
If the LED Is SOLID amber, it is likely either a component connected to the Motherboard or a bad motherboard
May 15, 2010 | Dell Dimension 4700 PC Desktop
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
Dec 08, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell 4500 won't turn on,power light amber/green
Is the light more amber or more green? If you push the button and it goes amber, then you probably have a bad power supply. Try getting another power supply to test. If that doesn't solve the problem, then you probably have a bad motherboard.
Oct 22, 2009 | Dell Dimension 4500 PC Desktop
PC will not start-up after sudden crash
try unplugging the power cable, holding down the power button for 10 seconds, then plugging it back in and turning it back on. also, there should be a set of 4 lights on the back of the dell (A, B, C, and D) for diagnostic purposes. Check them and compare them to your model's light diagnostic look-up on Dell's website.
Mar 25, 2009 | Dell OptiPlex GX270 PC Desktop
Amber light on power button of Dell Dimension 4500
ok - the amber light of doom on a dell means one of two things - either your power supply is pooched - or your motherboard, If under warranty dell will send out a friendly tech to replace them - if not it will cost you a bit. get the price and consider if it worth upgrading instead. Contact your dell rep or dell tech support and see what they say
cheers Pete
Nov 30, 2008 | Dell Dimension 4500 PC Desktop
Dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Oct 18, 2008 | Dell Dimension 3000® Pentium® 4...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
