Question about Cobra Honda VT750 Shadow Aero Cruisers Exhausts
WHAT IS THE THROTTLE POSITION SENSOR SETTING FOR A 2004 HONDA SHADOW
2004 Honda VT 1100 C2 Shadow Sabre starts, but dies when throttle is opened
Hi, Anonymous and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts choke but dies with little throttle
http://www.cyclechaos.com/4um/f66/2007-shadow-sabre-vt-1100c2-starts-but-wont-stay-running-41995
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Jun 28, 2014 | 2004 Honda VT 1100 C2 Shadow Sabre
What is the position of the fuel shut off valve for reserve tank on a 2004 Honda VT 1100 C Shadow Spirit
Hi, Anonymous 99% of fuel valve positions are as follows with the long end of the lever pointing:
1. Forward=off
2. Down=on
3. Up=reserve
Fuel shut off valve position
Fuel shut off which way is reserve
Jun 14, 2014 | 2004 Honda VT 1100 C Shadow Spirit
2004 Honda VT 1100 C2 Shadow Sabre throttle linkage loose
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Throttle Cable Adjusters
Motorcycle throttle cable adjustment MP4
May 07, 2014 | 2004 Honda VT 1100 C2 Shadow Sabre
2004 Honda VT 750 Shadow Aero stalls when tilted
Hi, Anonymous you may have a faulty lean angle sensor for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Shadow Forums Shadow Motorcycle Forum
Shadow keeps dying
Honda VT750C2 Shadow Spirit Service Manual
Honda VT750C2 Owner Manual
Apr 26, 2014 | 2004 Honda VT 750 Shadow Aero
2004 Honda VT 750 Shadow Aero stalls applying throttle
02 shadow spirit 750 dies if given any throttle Shadowriders
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
Apr 17, 2014 | 2004 Honda VT 750 Shadow Aero
How to replace a throttle tube on a 2004 honda shadow
Hi, Carlene for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing and printing please click on the blue links below. Good luck and have a wonderful day.
Anyone know how to re install throttle tube
VT1100C2 Throttle cable replacement
Jul 24, 2012 | 2004 Honda VT 750 Shadow Aero
2001 Honda VT 750 DC Shadow Spirit throttle grip mystery
Hi, Chrisdaily the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Honda 2001 VT750C3 Owner Manual
2001 Honda VT750DC Shadow Spirit
Honda Shadow Wikipedia
Jul 28, 2017 | 2001 Honda VT 750 DC Shadow Spirit
Changing throttle position sensor on a 2004
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the throttle position (TP) sensor electrical connector.
  3. Remove the screws and the TP sensor.
Throttle position (TP) sensor electrical connector
TP sensor
To install:
  1. Install the screws and the TP sensor. Tighten screws to 7 inch lbs. (3 Nm)
  2. Connect the throttle position (TP) sensor electrical connector.
  3. Connect the battery ground cable.
Apr 25, 2010 | 2004 Ford Taurus
2004 Honda Shadow Aero stalls
sounds like bad fuel try adding some fuel stabilizer.
Jul 19, 2009 | 2004 Honda VT 750 Shadow Aero
2004 Honda Civic -Code P0122 Throttle Position Sensor Voltage Low
yes, this is the case of a failed throttle body, in which case it needs replaced, the car is getting too much fuel causing the high idle. this needs replaced asap. you could proably find a small independant honda shop that could do the work for less.
May 12, 2009 | 2004 Honda Civic
Cobra Honda VT750 Shadow Aero Cruisers Exhausts Logo
59 people viewed this question
Top Cobra Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cobra Cycling Expert? Answer questions, earn points and help others
