Question about Browning Gold Series Premium Dual Combination Locks Gun Safe Color: Gloss Burgundy, Embellishment: Mule Deer Scene"
Peugoet 207 door will not close and lock - Browning Gold Series Premium Dual Combination Locks Gun Safe Color: Gloss Burgundy, Embellishment: Mule Deer Scene"
Peugoet 207 digital display fades at intervals when driving ,then will be perfect for a while .
lost power to display (hint use a voltmeter to see if ok)
or
bad display.
Jul 10, 2014 | Cars & Trucks
Passenger door has dropped and has to be lifted to close can any one give any guidance
It sounds like the hinge bolt came loose. If it comes loose, the door can sway up and down. I would check that, and if this is the case, get somebody to help you by lifting the door up on the end of it while you tighten the bolt. You have to get it just right, it may take a few times.
Apr 03, 2014 | 2006 Peugeot 207 1.4
How to remove the back seat of my peugoet 307cc
I had the same situation today. The rest of my car was open but the keys were locked in the boot. Fortunately, using a long, hooked rod, a nice man was able to fish the keys out from inside the car. Just above the back seats, the plastic is soft and flappy. You can squeeze tools in and out through there (and an arm at a push) and try to fish the keys out. I hope this helps other Peugeot owners.
Dec 31, 2012 | 2007 Peugeot 307 CC
207 cc drivers window won't close
the motor in the drivers door is probably bad. check to make sure it has power and ground with a test light at the motor with the wires unpluged.
Jun 08, 2012 | Peugeot 207 Cars & Trucks
Have peugoet 207 3Dr problem with doorlock..I tride kids safetly lock,pushing lock down on side of door..And know lock doesnt open, cannt close door??????????
you will need to remove the trim with the door shut ,the pop the lock with a screw driver to get it opened,it would be better if you took it to a mechanic
Apr 30, 2012 | Cars & Trucks
What does the error code CH stand for? Sharp AR 207
ONE OF THE DOORS SWITCH IS OPEN ,CLOSE THE RIGHT HANDS SIDE DOOR VERY WELL, AND CHECK THE FRONT DOOR ALSO
Sep 04, 2010 | Sharp AR-207 Copier
How do i release the child locks on my peugoet 305 2005 model
there should be a switch located near the latch in the end of the door, my BMW is located on the latch itself
Mar 25, 2009 | 2005 Peugeot 405
Browning Gold Series Premium Dual Combination Locks Gun Safe Color: Gloss Burgundy, Embellishment: Mule Deer Scene" Logo
64 people viewed this question
Top Browning Home Security Experts
Lawrence Oravetz
Are you a Browning Home Security Expert? Answer questions, earn points and help others
