My door switch has burned out 3 times in the past 12 months. What could be the reason for this?
I have a Whirlpool LEW005PQ. It's about 7 years old and was working fine. When it stopped working we called an engineer to look at it who said it was the door switch which had burned out. He gave us a ridiculous quote for the repair and I looked at how to repair it and found it was actually quite an easy fix so did it myself. This was 12 months ago and was replaced. It has since burned out twice more and I'm baffled as to what could be causing this. Please could you tell me what checks I should do to avoid this happening again.
  • Washing Mach... Master
  • 2,344 Answers
First, let me guess. Did you happen to buy plastic "cheap" ones? These days, that may be all that is available. Manufacturers are going for parts that cost a few pennies to make.
For a solution, I would check your grounds. Start with the back of the machine where the cord attaches. Make sure the wires are good and are tight. Then, check the cord, and the place where the cord plugs it. Take it apart. Check for good and for tight connections. Go then to the house or apartment fuse./circuit breaker box. A bad or poor ground can cause electricity to do crazy things, just like you have described. Be blessed.
Posted on Feb 24, 2014
2 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Bosch WVD24520GB washer dryer runs a wash fine but
If your dryer is a condenser type maybe you need to yank out the condenser and give it a good clean. Could not make the model number posted work.
Posted on Sep 21, 2010
Fridge portion doesn't get cold
The defrost circuit is not working, there are usually 3 things that normally go bad, defrost timer, defrost heater, and thermal switch. Would have serviceman check it out as cooling fins on coils will cut you like a razor.
Jul 24, 2017 | Whirlpool Centralpark 25.6 Cu. Ft....
Where to get service
We have no means to recommend a local business.
Jul 24, 2017 | Sunbeam Sm0701a7e Microwave Ovens
Ek Dada, Ek Bap, Ek Pota, Tino ki age 140 yers. Pota jitne month ka dada utne sal ka, pota jitne din Ka,.Bap utne week ka, WHAT IS THE SOLUTION?
OK here it is.
Dada is 84 years old (grandfather)
Baap is 49 years old (father)
Pota is 7 years old (grandson)
Check: 84 + 49 + 7 = 140 years
Read below if you want to know how to solve (Its a simultaneous eq. of 3 variables bdw :)):
Let Dada be D years, Baap be B years and Pota be P years
D + B + P = 140 (given)----------------------------- (1)
Constraints:
D = 12P; --------------------------------------------------- (2) 1 year is 12 months; 52 weeks; and 365 days
52B = 365P; --------------------------------------------- (3)
Substitute value of P from (3) into (2) therefore D = (12 * 52/365)B ------------------- (4)
Put (4) in 1 to get
(12*52/365)B + B + (52/365)B = 140
This gives B = 49 years. Put in above eqs to get other values.
Dec 04, 2010 | Computers & Internet
Year lo 1 time month lo 2 times weekly 4 times rojulo 6 times vachedi enti ?
year lo 1 time(12 months: 1+2=3 odd)
month lo 2 times(1 week and 3 week these are odd numbers)
week lo 4 times(1 Sunday, 3 Tuesday, 5 Thursday, 7 sat day)
day lo 6 times( 1o clock, 3,5,7,9,11)
Jun 07, 2010 | Nokia Lands Phones
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
My JVM1851 model is 7 years old. Everything is working (light, fan, clock, etc). But food does not cook or warm. no heat!!!
As I understand your trouble, your 7 year old microwave does not heat.
I have found the most likely reason for this trouble is a burned door safety interlock switch.
To fix this trouble, remove the cover, find the switch opposite the door hinge. Test the switch for proper operation. You will need a continuity tester or a volt/ohm meter for this.
Let me explain what happens and you will be able to apply this to your situation. When you close the door these switches tell the oven the door is closed and it is ok to turn on the magnatron. If the switches are burned, they cannot tell the oven the door is closed - door not closed, no magnatron, no magnatron, no heat.
Why do they burn? Do you open the door while the oven is in operation? If you do, there is a spark at the tiny micro switch contact and they start to burn. Eventually, they will not close properly.
You can find replacement parts at a FixYa.com advertiser or a appliance parts store in your area or at www.repairclinic.com
The next most likely problem is the start capacitor. This is the silver can inside. Please do not servic this item unless and until you understand the danger associated with it.
This device stores a very large electrical charge. Modern capacitors are supose to drain off the power after a certain amount of time. Some say it is OK to drain the opwer by shorting with a screw driver to ground. Frankly, I'm not a fan of this method. Please try the switches first ... if that doesnt work, post a note here and we can go to the next step.
I hope this solves your trouble and you are able to get your oven back in operation. If you will search this problem here at FixYa.com, you will probably find other ideas from other volunteer workers.
Thanks for using FixYa.com. Please vote
thanks
a
Nov 09, 2009 | Microwave Ovens
I want to set the time and date on my calculator and need help Please give me the directions
1)Press TIME/DATE and then SET (The first digit of the month will flash)2)Enter the month MM using the number keys.
(The first digit of the date will flash)
3)Enter the date DD using the number keys.
(The first digit of the year will flash)
4)Enter the year YYYY using the number keys.
5)Press SET to confirm the date.
6)Press TIME/DATE and then SET. Enter the time using the number keys and press 12/24 to switch between 12-hour or 24-hour clock.
7)Press AM/PM to toggle morning or afternoon and press SET to confirm the time.
Oct 24, 2009 | Victor 1208-2 Calculator
Shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The black door switch (whenengaged the dryer starts) has come looses and the3 dryer wont start. its a whirlpool thin twin W/D stacking unit. its about 12 years old.
Hello rkomita, the door switch is a NESC requirment. The model# in www.whirlpool.com/custserv/index, search for service manual. This can give the info on layout of switch location, replacement, wiring & mounting. If you attempt the repair DISCONNECT THE AC POWER FIRST. I will gladly help if you need it.
Nov 11, 2008 | Whirlpool Dryers
My new front loading washer is not spining. It is 3 months old. We have a 12 month warranty and labor
call whirlpool customer service, they own maytag now, you will be covered under warranty.
Mar 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
