Question about Optimus DS-5080 Digital Camera
My camera will not turn on when I slide the lens cover switch and will not charge when plugged in.
My camera has been working fine and all of a sudden it will not turn on and will not charge. Why?
    Top Expert:
  • Optimus Master
  • 6,702 Answers
When the battery is empty, you can't switch on the camera. Why does it not charge?
Could be the switch behind the lens cover does not work correct or not at all. Could be the power cord is not ok. Or the socket where the cord goes into the camera.
Can you try to charge the camera on an external charger and when it is charged, try switching on again.
Posted on Feb 13, 2014
Testimonial: "Update: The camera was working fine. External charger is putting out 5.1 V, Battery checks with 4.2 charge. All of a sudden the camera will not charge and will not turn on when slide switch is operated. I cannot find any schematics or local repair sites. Any suggestions?"
I get a "system error" when I turn on the camera. battery seems to be charged. thank you...
This error usually comes due to faulty sliding mechanism.Put a bit of force on the focusing lens to push it back into camera casing. That's the reason the sliding mechanism won't work. The lens is stuck and if you force it back in, the sliding mechanism will work again. Not responsible if your camera screws up, so try at your own risk.Or else try out this method.Pull the lens fully out and then it will work.It will be bit tricky to get the lens out. Use your nail to "grab" between the outer glass and the little plastic cover.
Thank you !!
Aug 17, 2010 | Nikon Coolpix 2500 Digital Camera
Camera part won't power on
I had the exact same issue with the D-395.
I wiped off the battery contacts and the ends of a newly charged set of batteries to make sure they were clean. Also while the batteries were out, I opened and closed the lens barrier or sliding cover to try and drain any juice still in the camera. I put the batteries back in and slowly/gently slid open the lens cover. It turned on and works fine now.
Nov 08, 2009 | Olympus Camedia D-395 Digital Camera
I have a Cannon Powershot SD600, just got it recently and it worked great, then all of a sudden I noticed the cover lens's that slide over to protect the lens when you shut it off were messed up. Onle 1...
The Canon series are fine camera's, but they seem to suffer from lens errors (check how many people suffered from this by googling lens error canon).
The problem seems to come from sand/dust entering the body and jamming the lens gear. A handy person may be able to fix it, but I think Canon should have designed an enclosed lens gear so sand/dust can not enter.
Camera's are commonly carried in pockets, so it is logical sand and dust can be expected.
There are some issues with getting perfect focus in some situations.
Jan 03, 2009 | Canon PowerShot SD600 Digital Camera
Cybershot DXCS60 carl zeiss vario-tessar auto lens cover is sticking closed
There is a switch at the back of the sliding cover of the lens that is on when the cover is slided down (lens uncovered). You should try to take off the back cover of the camera where the sliding cover is and try to fix that switch.
Jul 28, 2008 | Cameras
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Apr 28, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
No power !
As indicated in solution #2 dirt deposits in the channel that prevents the cover from moving the switch to turn on the camera. To get at the channel to clean out the **** remove the 6 small screws (two on each side and two shorter screws on the bottom of the outside of the camera). Remove only the six screws that are holding the front of the camera body on. The silver band seperates the front of the body from the rear. Wiggle off the front of the camera body. With the lense cover closed you can wiggle off the plastic inside of the front cover from the exterior of the body. By doing this you'll expose the track that the lense cover rides in. Notice that the top track moves back to contact a black plastic switch. **** will typically be in the channel preventing the lid from contacting the black switch. Clean it all out and reassemble. Camera should work fine.
Sep 06, 2006 | Konica Minolta DiMAGE G600 Digital Camera
Optimus DS-5080 Digital Camera Logo
67 people viewed this question
Top Optimus Cameras Experts
Jerry Greenberg
Jerry Greenberg
Starnley Johnwells
Starnley Johnwells
John Emerson
Level 1 Expert
Are you an Optimus Camera Expert? Answer questions, earn points and help others
