Question about Kodak i1420 Pass-Through Scanner
Hardware issues - Kodak i1420 Pass-Through Scanner
How to fix my laptop? by the time i open it will shutdown automatically and cannot open
first of all we have to check if it is a hardware issue or the operating system issue
to get this information
leave you computer at bios screen
if it restarts in bios screen as well then it is a hardware issue
howveer it is not restarting in bios then it is an operating system issue
for hardware you need to contact hardware specialist
however for o/s, you can scan your computer for virus if possible otherwise the last option is operating system reinstallation
Aug 17, 2011 | Computers & Internet
Likom lcd autonatic shutdown
Sounds like a hardware issue. Make sure your settings on your computer are not causing it.
If its not your settings then it is a hardware issue with the monitor which sadly means you will have to send it to the manufacture or someone who does hardware repair.
Jul 22, 2011 | Likom HD15A 15" LCD Monitor
My usb is not working
check,if the issue is only with that particular port,or all the ports if issue with all the ports,try uninstalling and re-installing the port drivers from device manager DEVICE MANAGER- RIGHT CLICK ON MY COMPUTER SELECT PROPERTIES SELECT THE THIRD TAB-HARDWARE FROM THE LIST OF HARDWARE,SELECT THE USB , AND RIGHT CLICK AND SELECT UNINSTALL AND ON THE TOP OF THE WINDOW,SELECT,SCAN FOR HARDWARE CHANGES hope,this will fix the issue
Apr 23, 2011 | Computers & Internet
X c b n m 1 these keys wont wrk
If this is a new issue and you have not changed any software recently, then this is almost certainly a hardware issue. You should contact your computers manufacturer for information about any know issues or replacement hardware.
Best Wishes!
Mar 28, 2011 | Computers & Internet
How do i fix my sidekick lx 2008 hardware problem
Depending on the hardware issue weather its a broken screen, keyboard, or firmware failures.
You can purchase parts from this site click here
1. State in what means of hardware failure your speaking of.
2. Be detailed in your question's to us so we can get back to you with a quality reply.
A hardware problem could mean anything from no power on to a broken or non-responsive unit, the list goes on.
A phone the presents issues with its main-board will not be worth the fix.
I sure hope this does help please do update with details of you hardware issues.
Oct 28, 2010 | T-Mobile Sidekick
TRYING TO RECOVER LAPTOP, GETTING THE ERROR MSG 10-FC 12-045D
Based on the information available online and the suggestions provided by the Computer Experts, the error might be occurring due to any issues with the Hard Drive of the Computer.
However, to confirm if the issue is related to the Hard Drive, please perform the steps mentioned below:
1) Turn OFF and turn ON the Computer.
2) Then, go to the BIOS Menu.
3) In the BIOS main menu, check if the Hard Drive is listed there.
4) If the Hard Drive is not listed in the BIOS main menu, please go to the "Boot" tab.
5) In the Boot tab, the Hard Drive should be mentioned along with the Hardware components of the Computer such as CD/DVD Drive etc.,
6) Check if the Hard Drive is listed on the BIOS main menu or the Boot tab.
7) If the Hard Drive is mentioned in the BIOS, this indicates that you can try some more troubleshooting steps, before getting the Hard Drive replaced.
8) If the Hard Drive is mentioned in the BIOS, you may try performing the Hardware Diagnostics.
9) The Hardware Diagnostics can be performed by using the Recovery Tools.
10) The Recovery Tools will pre-installed with all the OEM Computers.
11) For some Models, the Recovery Tools should also be supplied with the Recovery Discs.
12) Performing the Hardware Diagnostics will perform a complete scan for any errors or issues with the Hardware Components such as the Hard Drive, RAM etc.,
13) If there are any issues with the Hard Drive, RAM etc., they will be mentioned in the detailed report of the Hardware Diagnostics.
14) Once, the Hardware Diagnostics is complete, you may again try performing the Recovery.
15) If the issue still persists even after performing the Hardware Diagnostics, then the issue might be Hardware related.
16) The issue might be with the Hard Drive.
17) It would be better to replace the Hard Drive, if the issue still persists even after performing all the above steps.
Hope this helps.
Please feel free to ask further questions.
Aug 15, 2010 | Computers & Internet
Windows says computer(gt5040) has a hardware issue....
try re fitting of processor.....replace RAM module with other slot...check data cable for HDD and optical drive whether they are inserted properly....
Oct 09, 2009 | Gateway GT5040 PC Desktop
Hardware attack
Having similiar issues with the i6780. We are experiencing high percentage of hardware attacks/loss of encryption. Talked with ingenico support, they made reference to a known board issue, but i have not been able to get any details.
Jun 30, 2009 | Ingenico 6550 TERMINAL OPOS POWER SUPPLY...
PROBLEM IN SOUND DEVICE
What hardware device drivers should be updated? A listing and recommendation of computer hardware device drivers that should be ... A listing of computer sound card drivers can be found on our sound card .
Issues relating to msgrv32 Resource conflict or issue; TSRs or other running programs; Sound driver or sound card issues; Onboard sound or video issue; MIDI device or codec issues
POST troubleshooting steps. Bad or failing hardware device. Connections not connected or connected properly. ... if you press the power button and nothing happens (no lights, no sound.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer TravelMate 2300 Notebook
Kodak i1420 Pass-Through Scanner Logo
23 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
