Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I have a Maytag refrigerator model MTB2176HR. Both the fridge and the freezer are no longer cold. I also hear a clicking sound approximately every minute odr so. It sounds like a relay switch being triggered.
  • Kenmore Master
  • 4,655 Answers
Believe if you replace these parts=> 12002794 Relay and Overload Kit and pay attention to the comments made during the tutorial video you will be fine, Thanks John Tripp Appliance 911
Posted on Feb 13, 2014
22yooper
  • 828 Answers
SOURCE: Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Posted on Jul 16, 2008
Sea Breeze
  • 4655 Answers
SOURCE: kenmore coldspot side by side refrigerator - freezer fine. other
Good to see you put your model number down correctly. Do the lights come on inside when you open door? I noticed your refrigerator has a control board inside the fresh food section behind the control panel I want you to unplug the refrigerator and examine that board for burn marks or loose solder connections on both Sides. Then let me know what you find. Thanks, Sea breeze My email is appliancepsrtsse@yahoo.com Web Site http://servicepartstec.blogspot.com/ Part Number for Control board is 8201528
Posted on Jun 11, 2009
  • 89 Answers
SOURCE: Refrigerate not working freezer not working
sounds like the relay is bad replace the relay this should take care of the problem it is located on the compressor
Posted on Jul 11, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
Posted on Aug 19, 2009
Testimonial: "I'm going to check this out right now. Thank youy for your input."
heatman101
  • 43501 Answers
SOURCE: Refrigerator is not cold, freezer is
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 26, 2010
Why is my freezer warming up?
Sounds like your heater/defroster went bad and by now there is probably ice build up and fan can not push the cold air to the freezer. Very easy fix but you will have to buy new heating cable ($25-40) and strongly advise to buy a new thermostat as well(around$10) it snaps on heating cable and controls power to heating cable whenever there is ice build up.
Apr 26, 2014 | Maytag MTB2176HR Top Freezer Refrigerator
Freezer not cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 02, 2012 | Maytag MTB2176HR Top Freezer Refrigerator
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Water collects in refrigerator which is below freezer
use air from bottom of fridge, but you will have to clear top drain eventually
May 04, 2012 | Maytag MTB2176HR Top Freezer Refrigerator
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
The fridge compressor only works periodically
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 24, 2011 | Maytag MTB2176HR Top Freezer Refrigerator
Freezer not cetting cold
The first thing you should do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck.
Aug 13, 2010 | Maytag MTB2176HR Top Freezer Refrigerator
Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Drcool
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
141 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
