Inpage Urdu Publisher has stopped working
When i open a file of inpage. Programe crashed and below give error: Inpage Urdu Publisher has stopped working Problem signature: Problem Event Name: APPCRASH Application Name: InPage.exe Application Version: 3.0.5.0 Application Timestamp: 4cf3a097 Fault Module Name: ntdll.dll Fault Module Version: 6.1.7601.18247 Fault Module Timestamp: 521ea8e7 Exception Code: c0150010 Exception Offset: 0008482b OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 3e06 Additional Information 2: 3e0616bd1386f7365798695bf091efc8 Additional Information 3: df9d Additional Information 4: df9d7d09652fc2e4ea84eaf2d59c129e Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
5 Suggested Answers
  • 9 Answers
SOURCE: Problem signature: Problem Event
Try this
  1. Go to the Control Panel and click Printers
  2. Right-click on the white space and click "Run as administrator > Server Properties"
  3. Click on the "Drivers" tab, click on the offending printer and click on the "Remove" button.
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
Posted on Feb 01, 2010
rh10
  • 122 Answers
SOURCE: Close the Programe (Notice)
User permissions issue. Go to C:\program files\microsoft\fsx and find the fsx.exe icon. Right-click it, choose properties, and tick the check box for "always run as administrator". This process doesn't always work doing this from the FSX shortcut.
Posted on Jul 12, 2010
  • 2291 Answers
uninstall ym and run reginout cleaner to fix registry errors, then install ym it will work
Posted on Nov 05, 2010
  • 114 Answers
SOURCE: windows 7 problem
try to connect the usb HDD in windows with safe mode(by pressing F8 while booting ) and try to check the HDD system disk by windows tool, this might solve some errors. and restart ur device & can work normally then, if windows found errors on ur harddisk & fixed them. good luck
Posted on Jan 09, 2012
Fix Error performing inpage operation
did you try unhide/reset attribute? in Windows you can use "attrib" command. Since you familiar with "chkdsk" command, so i assumed you have no problem how to use "attrib" command. Good luck!
Jul 30, 2017 | Seagate FreeAgentĀ® GoFlex? Desk 3TB Hard...
Computer clicks then shows the kernel data inpage error screen
I'm sorry to say but that sounds like a hard disk failure. Classic symptoms.
Run a diagnostics test using Seatools:
SeaTools Seagate
Mar 21, 2014 | ASUS Silver 15.6" Vivobook V550CA-DB71T...
Inpage error for transcend external hard drive 500gb
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
hope it helps
May 25, 2012 | Transcend 500gb Storejet Mobile Red Usb
I have a problem with inpage urdu 2000 2.4.it give me err again and again please help me that how can i solve this problem.thanks
You can download the newer version of Urdu Inpage 2009 from the link below
Make sure you delete all the old version of inpage from your system, Specially from C:\inpage 2000 or C:\program files\Inpage
Download here
You need to have winrar installed in your system to extract the rar file
Good Luck!
If you require more assistance feel free to reply to this post
Thanks for contacting FixYa!
Regards, Bilal
Feb 16, 2011 | Computers & Internet
E: is not accessible Error performing inpage
dirve e not open there is problems of error performing inpage
Mar 10, 2010 | Transcend USA 120GB Storejet 2.5" SATA -...
"Error performing inpage operation" - External drive
hi
run this command from command prompt
Administrator>chkdsk e(your drive letter): /F
if problem persists just post your problem again..
as soon as possible you problem will be solved.
have a nice day
May 19, 2009 | Iomega Computers & Internet
Maxtor 80GB External HD
1. I need to know the brand name , model number , or motherboard you have
2. I need to know what operating system you are using
and when you say open , in what manor do you mean open , in what way are you attempting to open the drive and with what program , so far it looks like you may need to reinstall the computers operating system from scratch , because something is dead wrong , and it looks like a file system error , as if your computer operating system is no longer able to access files properly.
I consider your situation unresolved at this time untill you can give me more information.
I'm trying to reach guru status here in order to help people like you in a far more proper manor.
together we can solve it.
shalom
Aug 05, 2008 | Maxtor Hard Drive
I've just fixed the problem of error performing the inpage operation by using old DOS command CHKDSK <driveletter> /F. And, i'm satisfied with the MS-DOS command.
Jun 18, 2008 | Computers & Internet
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Kernel data inpage error
It is best practice with a used computer to completely format and
clean-install Windows. In your case, this is what you definitely need to
do after performing some hardware diagnostics. Here are links that will
show you how to do a clean install and what you will need on hand:
http://michaelstevenstech.com/cleanxpinstall.html
http://www.elephantboycomputers.com/...alling_Windows
Jan 02, 2008 | Toshiba Tecra M1 PC Laptops
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
