Question about Medion Televison & Video
Taking the back off a Medion 19" Flat TV
Having taken all the screws out the left hand side (as seen from the front) wont come off. Can you help at all? Thanks Syd Walker
    Top Expert:
  • Medion Master
  • 74,377 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Disassemble procedure to many popular brand TVs are given with illustrations.
Posted on Feb 14, 2014
bestdarngood
  • 3037 Answers
SOURCE: sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where your problem is coming from but most likely it will be the power supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c flipping off and on and current demand being peeked from the utilities storms or quick power loss off and on can cause problems like this to occur
Please let me know if you have any other questions, thanks
Posted on May 14, 2008
smarthome2
  • 1114 Answers
SOURCE: Left side of 52 inch Samsung flat screen tv is cracked,
You need to buy a new TV. Even if the screen is the only issue, it will cost more to repair it than to buy a new one, and it will take months since screens are in very short supply. Check with your homeowners insurance, it may be covered since i'm sure it was an accident and that's what insurance is for. Sorry.
Posted on May 23, 2009
khaye_cutee
  • 9 Answers
SOURCE: Tv saying NO INPUT
maybe there is no signal
but can you try putting it on tv mode?
Posted on Jul 20, 2009
John-INSG
  • 312 Answers
SOURCE: My insignia 19 inch flat panel wont power on...
Your TV most likely requires service. You may take the unit to the retailer of service to arrange for repairs. Note: physical damage that may have been caused by the unit tipping over would not be covered under the factory warranty.
Posted on Sep 25, 2009
welcomejee
  • 10594 Answers
SOURCE: sony 42in xbr flat screen user's manual
Let me know exact model of your TV and do you see any label on subject port that you want to turn ON, how it looks like?
Posted on Jan 18, 2010
Lcd tv black screen
Dear Antony,
sometimes power supply board problem,some times back light cct problem and last is main board problem.
minor damage is loose connection of solder joints.
and if you are able to open the covers and do the repair please let me know.
i will guide you.
regards,
nuwan
Jan 08, 2014 | Medion Televison & Video
Its leaking out of the drain at the bottom on the left hand side. I have taken it off and cleaned it out and screwed it back on and contiu=nues to leak.
Hi - I believe the problem will be with the actual drain pump, the seals have seen better days, unfortunately the manufacturers do not suply seal kits.
You will have to get the pump replaced - what you have done is open the pump housing from the front, useful, thats how you unblock the pump as its fixed in the very back of that drain system.
Jun 22, 2011 | Miele Touchtronic W1213 Front Load Washer
How to replace both inner and outer tv screens ?
Relativity easy to do yourself, but better if you have some one to help, all you need is a Philips head screwdriver, and the replacement screens, the technical name for them are Lenticular Screen, and Fresnel, one is white, and the other is black.
You start by taking off the screws in the back of the the TV, there are screws along the top, both sides, and there are two on the the bottom right, and two on the bottom left, and there are three on the front by the power and channel and volume buttons. then grab one side and have your partner grab the other, and pull straight off.
IMPORTANT!!!!! DO NOT TOUCH THE WHITE SCREEN WITH YOUR BARE HANDS, IT IS COVERED WITH A POWDER AND CANNOT COME INTO CONTACT WITH ANY FLUIDS, INCLUDING THE OIL ON YOUR HANDS!
There are four bars that hold the screens in, one on top, bottom left and right. to remove the top, left and right you have to wiggle them loose after removing the screws.
The Black screen will go in first, make sure that the smooth side is what you will be looking at when you are done, the white screen will go right on top of it, the rough side of the white screen will meet with the rough side of the black screen.
then put the screen assembly back on, and replace screws.
I hope this helps, if you have any questions, let me know.
Mar 16, 2011 | Mitsubishi WD-73735 Television
HI how do I remove the tv stand part because i want to mount it?
After disconnect power/antenna/any AV wires, turn your TV. Look at back side of your TV (on TOP of Stand part). You should see some screws there. To remove your stand, you should unscrew them all. Then Hold your stand and pull UP your TV. Be careful with your TV once your stand taken apart .
Nov 28, 2010 | Proscan 19LA25Q 19 in. LCD Television
Where is the lamp for sony lcd projection tv model # kdf-e60a20 located in the back?
To replace the lamp go to link below then click on operating instructions. then go to page 76. It will tell you how to change lamp.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDFE60A20
Dec 23, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
How do I remove the stand from my LN-S1951W LCD TV?
The stands, from what I've personally seen, are usually attached with 2-4 screws on the back of the tv or sometimes on the underside of the stand. I've seen it even where the bottom piece of the stand pops off to reveal the screw(s).
Hope that helps :)
Nov 05, 2009 | Samsung LN-S1951W 19 in. LCD Television
Apex tv
should be inside the back cover on the left hand side toward the rear of the television
Feb 18, 2009 | Apex Digital AT3208S 32" TV
Lens error 12 appears on screen, lens wont retract and camera turns itself off. How do I fix this
It is very easy to fix. Just Be Very Careful when doing the following Repair.
You will need the Following a Size 0 Screw Driver, and a Small Eye Glass Flat Head Screw driver.
1. remove the 4 Screws holding the side panels. (Make sure you do not mix these screws with the ones on step 2) as these screws are shorter.
2. Remove the 6 Screws on the bottom of the camera
3. Now carefully pull apart from the bottom up. You will see 2 more screws on the left side but do not remove them.
4. Seperate the Front faceplate carefully around the Lens assembly.
5. while keeping the Camera with the lens Facing Strate Up, remove the Two Screws on the right side of the Lens, but keep caution not to move the camera while the screws are out of place.
6. remove the Cover to the Lens Gears.
7. Now this is very important!!!!, Take the Small Eyeglass Flat head Screw Driver and Pry the Gear To the Left, not the one by the motor. you do not have to take the gear off, however just enough to allow you to Move the Lens Assembly manualy.
8. Turn the Lower half of the Lens assembly carefully until the Lens is compleatly In and lens protector flaps Shut.
9. Put the Gear back on.
10. put the Gear Cover back on and Screw the Two screws back in. Make sure they are Firmly tightened
11. Put the Front Face Plate back on by putting on the top first, then closeing the bottom.
12. make sure the side pannel with the Wrist Strap is in Correctly before screwing it in.
13. Place the Side Pannels back on and Screw them in.
14. Screw the 6 Bottom Screws back in.
Now put the Battery Back in and test it out. This should fix the error you were having. i just perfomed this on my camera 15 min before i Wrote these instructions it worked! Step 15 get back to taking great shots!
jakthebomb
Nov 24, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
How do i open the 300gl box
Opening the case is a breeze; remove three large thumbscrews, and you're in.
Jun 01, 2008 | IBM PC 300GL PC Desktop
LCD TV
There is more than two screws holding the back cover on. I think it is more like 4 to 6. After you have removed all the screws you will nee a flat screw driver to help pry the two halves apart. Be careful the front of the cover has little snaps that help hold the two together.
Jan 05, 2008 | Samsung LN-T1953H 19 in. LCD HDTV
Televison & Video Logo
Top Medion Televison & Video Experts
Raj Patel
Electro Med Services...
Andrew Taylor
Andrew Taylor
Are you a Medion Televison and Video Expert? Answer questions, earn points and help others
