Question about Xerox Laser Printers 4600/DN Phaser 4600DN Monochrome Laser Printer
Phaser 4600 registration jam - Xerox Laser Printers 4600/DN Phaser 4600DN Monochrome Laser Printer
2 Suggested Answers
  • 86 Answers
SOURCE: paper jams
Check to see if there is anything stopping the paper like a small piece of paper/paperclip.
Also see if the reg rollers are turning.
I DO HAVE A FULL SERVICE MANUAL FOR THIS MACHINE ON DISK AVAILABLE
try the top 2 things if you still have the problem please get back to me.
Thank You
Posted on Feb 19, 2008
HOW DO I CLEAR REGISTRATION JAM
Open the top cover, remove toner cartridge, jam should be below there. There's a common issue where the grey transport belt break underneath the toner cartridge, inspect those belts to make sure both are intact and not broken. A picture of the belt is at link below
http://www.iteminconline.com/023n01310_023n01310-xerox-4600-belt-flat-rubber.htm
Oct 12, 2015 | Xerox Phaser Office Equipment & Supplies
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Nov 23, 2010 | Xerox Phaser 6180N Laser Printer
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
Phaser 8200 paper jam
Are you referring to the upper roller in the front of the machine ? Under the stainless steel assembly? If so, it is very likely you snapped the black actuator in the registration assembly. You have to order then entire assembly to repair it.
Believe me, it happens, Oh yeah, it happens, its easy to break without realizing you have.
Oct 30, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 6250
That problem is the registration clutch.
You have to order the registration assembly to get the clutch. It is located on assembly with the black and stainless steel roller, you have to pop out the imaging unit to see it.
But that WILL fix your problem. They changed the style of clutch also. It is more reliable now.
May 01, 2008 | Xerox Phaser 6250DP Laser Printer
Jams at registration roller!!
Jams at the registration roll often come from one of the pickup rollers breaking a pin that keeps them in place on the feed shaft. They are D shaped rollers about midway back when you remove the tray.
They will be stopped in different positions.
Online at Xerox.com there is a complete parts list under support and drivers.
Apr 19, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Apr 18, 2008 | Xerox Phaser 6250DP Laser Printer
Paper jams
Thank You
Feb 19, 2008 | Xerox Phaser 6250DP Laser Printer
Paper jam message
A couple of things.
On the left side of the paper path, there is a registration flag type sensor that a small piece of paper can be torn off on.
Also, if the paper has been caught on that flag, it may be broken.
Carefully look with a flashlight for just a corner of a piece o paper left in the machine.
I suspect possibly the flag has been broken on the registration sensor.
Nov 10, 2007 | Xerox Phaser 8500/DN Printer
Xerox Laser Printers 4600/DN Phaser 4600DN Monochrome Laser Printer Logo
135 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
