Question about Garden
Craftsman 2 stage snowblower 179cc ohv loses power in second stage
    Sergeant:
  • 459 Answers
Check your bellts and tension
Posted on Mar 06, 2014
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Does 4-stroke and 4-cycle mean the same thing?
yes ... intake, compression, power, exhaust .... vs 2 cycle which mixes them down to two.
Mar 30, 2015 | MTD PRODUCTS INC Craftsman 21" 179cc*...
Electric snow blower stopped working
Maybe it needs to be plugged into a wall outlet
Feb 16, 2014 | Craftsman 21" 179cc* Single-Stage...
Craftsman 179cc ohv 2 stage snowblower loses power in second stage throwing heavy snow
You should check for belt condition and adjustment. Under more load the auger/impeller belt might start to slip and would result in poor performance. For improved performance in wet slush there is an "impeller modification" that can be found with a web search. It's adding rubber wipers to the impeller blades and it does a great job of tossing that stuff out the chute instead of clogging it.
Feb 13, 2014 | Garden
Replaced shear bolts now engine will not turn over
Well look in the Housing to see if ther is something stopping it from turning over or the chain is stuck in drive and not movin
Feb 06, 2014 | Craftsman 21" 179cc* Single-Stage...
Auger keeps spinning after releasing handle
so what is your question as long as it is spinning when you are using it and it is throwing snow so what
Jan 26, 2014 | Craftsman 21" 179cc* Single-Stage...
Craftsman snowblower 179cc ohv
clean the carb , make sure you are shutting off choke after start this fouls the plug , good gas ?
Jan 11, 2014 | Garden
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 | Mtd Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
