Question about Miele S318 Bagged Canister Vacuum
When I turn on the brushes the light turns red
The beater bar wont turn...light turns red
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
Posted on May 12, 2012
I have strong hose suction but none below and beater bar is not turning
Beater Bar Belt Likely Broken--Can Be Checked By Removing Cover(s) Next To Beater Bar (on bottom)
Feb 27, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Beater bar
It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Dyson dc28 animal red light flashing and no suction
Clean any debris from around the brush bar. If this doesn't solve the problem you may need to take it to a qualified repair person
May 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Discover irobot brushs womt turn
Are they wrapped up with hair, thread, dental floss? If so clean them. Were the brush and beater bar replaced incorrectly in the past? The square end has to fit on the square side, etc.
May 13, 2014 | iRobot Roomba 560 Robotic Vacuum
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Sears vacuum beater bar wont turn...belt is good ..will turn by hand but motor wont turn it..
Check that the belt is not too slack and that the brush bearings are not too tight, or that some lint or thread is caught around the brush shaft.
Feb 03, 2011 | Vacuums
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Brush wont turn loose belt, new belt no help
may need to clean or replace beater bar. take brush out of vacum hold on the end and try to turn brush
Nov 26, 2009 | Vacuums
How do i change the belt on the bissell powersteamer 1697w????
Ok taking the cover off is good. I believe the the little red thing is the beater bar. This beater bar has brushes on it an extends the width of the vacum. Pull the beater bar out straight. Some times it is tight. Next is to place the new belt around the spindle in the back and slide the beatrer bar into the belt. No twists! Besure to have the beater bar with the seperated area with no brushes inline with the belt.Now place the beater bar in place. Make sure you turn the beater bar so on the side the slotted portion slides all the way in place. Replace your cover. Turn it on and try it.
I believe this will work. Let me know.
desmjs
Dec 14, 2008 | Bissell 6594 PowerForce Bagless Upright...
Miele S318 Bagged Canister Vacuum Logo
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
