Question about Western Digital Computers & Internet
Plzzz answer me .. I have WD 1TB outer HD and i do erase for it but i need to recovery my files ? I am try all recovery program but it dose not work ?? plzzz do you have solution to my problem ? plzz answer
  • dr_adnan94
    dr_adnan94 Feb 13, 2014
    I have pc windows 7 ... and wd 1TB outer HD ... the problem that by mistake I erase my passport :( plzz what can I do to recover my data and how can you help me plzz answer me
    New Friend:
  • 14 Answers
Hi, You have a one TB external harddrive. You plug it into your USB port. on your computer click start, click computer. question: does it show there. is there an icon? If so click open. what happens?
john
Posted on Feb 14, 2014
  • John Peabody
    John Peabody Feb 14, 2014
    john
  • 5 Answers
SOURCE: slow WD World Edition HD
I understand your pain. Mine was always slow, but it's by design. I am sure the limitation is the amount of RAM it has, because everytime it needs to access data, the RAM is so small that it will have to go back to the drive just to re-read an index. When mine died after 1.5 yrs, I took it apart and found a WD5000AAKS SATA 7200rpm drive. Performance of the drive should be excellent, but in that little plastic box that is acting like a stand-alone NT server, performance is s-l-o-w. As a MyBook, it's best used as a backup unit, but be sure you have a backup of that, since it is highly unlikely it will live much more than 12 months, if that, because it has no forced cooling. See other issues on this site with regard to other MyBooks.
Posted on Dec 09, 2008
Crankstart
  • 696 Answers
SOURCE: WD 1TB USB 2.0 EXT HD - NOT RECOGNIZED
Hi First things first, is the light on the front still coming on? If not try a new power supply or moving the drive to a new shell as the problem is either in the AC adapter or in the shell.
If the light is on it only confirms that you have power, but first try a different set of USB ports and if that doesn't work try a different computer. If it works on the other ports, no biggy, use it there. If it doesn't and works on a different computer then it's likely your registry entry for the device is damaged, get back to me if that is the case. If it doesn't work on other ports or another computer then it's likely the circuitry of either the drive or shell is damaged, take it to a computer store and have the techs swap it into a new shell(about $40). Then have them test it, if it works you're done, if not then it is the circuitry in the drive itself that is damaged and you will need to send it for data recovery if you want the files back.
Send me an update once you have tried these suggestions and let me know how you made out. If you require the help of a pro for the final steps, reply with your country and region and I will locate a reputable facility to assist you further.
Chris
Posted on Jun 04, 2009
crash748
  • 10 Answers
SOURCE: WD My book flashing light
I think you have burn your power supply coord! Sometime powercoord have the same plug but the voltage are not the same laptop run sometime at 18v when hd is at 12v. On your HD look arround the power coord hole, you should be able to find wich voltage you need to operate it!
Posted on Jul 07, 2009
SOURCE: I cant move large video file from my laptop to my 1TB WD Drive
Reformat the drive from Fat32 to NTFS.
Largest file size on Fat32 is 4 gig
Posted on Oct 14, 2009
NextStepComp
  • 185 Answers
SOURCE: WD ext hard drive cant access files - I/O error (think its bust)
Chances are the drop jarred loose something in the drive that on;y caused problems when the disks stopped spinning and started again. Here is a list of recovery tools that would do the job if there is something there to recover. http://www.snapfiles.com/Freeware/system/fwdatarecovery.html you will know within a couple minutes whether there is anything recoverable.
If it is that important you can send the drive off to www.OntrackDataRecovery.com and they should be able to get the files.
Posted on Jan 01, 2010
WD External Hard Drive Passport Ultra Beginner's Questions
Usually with an external hard drive it's not necessary for it to copy over an existing backup or at least you can program your PC not to do this. What will happen is you will have several different copies of backup's and you will have to decide if you want to erase the others and keep the most resent one. Yes your file will be saved withing the backup but if you change the file name it will file this as a new file
Sep 28, 2015 | Ultra Computers & Internet
Service center in bangalore
Yes this is easy using `Easy Recovery Professional` once the data is recovered you can re-allocate the partitions.
Jan 19, 2014 | Computers & Internet
I have WD passport 1TB i enter the pass word sevral times wrongly and the disk clear every thing how to recover it please help
There are several free file recovery programs out there. However if the password is still in effect then these won't matter. If it's wiped like the rest of the drive then recovered you then have the same problem have the same problem. If the recovery program does work it usually wants a different drive to write the files to.
Aug 01, 2013 | Western Digital Passport WDXML800UE...
I have 1 TB WD and i wanted to delete all files. Ques? will all those files will remain in my 1TB WD? or do i have to have it nuked to clear all the files? Please advised?
If you just press delete the files will stay hidden on the HD. If you want to flush the HD clean just format it. When you get the format option do not choose the quick option but choose slow.It will take longer time but will erase all data .
Sep 02, 2011 | Computers & Internet
Hi All , I have a 1TB WD HDD which i accidently removed when it was running.After that it has been noticed that the hard disk is not getting recognized on any machine. When i used a trial recovery...
Hi pavi66
A trial recovery software will show you the files present on your drive but will not let you recover them ! You need it and they need your monney , so , buy it or try Recuva from http://download.cnet.com/Recuva/3000-2242_4-10753287.html
Do not try to recover all at once but each category at a time , documents , pictures , music ...etc...
Otherwise , you need to buy a recovery software such as Tenor Share from : http://www.any-data-recovery.com/
Best regards ,
fanaudi .
Aug 07, 2011 | Western Digital My Book Essential 1TB...
External WD 1TB. I cannot retrieve my files it says Parameter is incorrect when that is gone It shows there are no files on my HD and there are plenty of files all psd files as well
I'm sorry to say that this may be due to a corrupt HDD. WD Hard drives tend to die far too fast (I know too well unfortunately).
If this is under warranty, I would call up WD support service for a free replacement.
If you want to take more invasive steps, I will be happy to help you try and recover your files.
Feb 23, 2011 | Western Digital My Book Essential 1TB...
Wd elements 1tb hdd write protected help
the volume of the partiton is corrupted, u need to use winpe mini cd or hirens boot disk to realocate partitions and fix the volume with active partiton recovery programe.
or an alternative way, use a linux live cd, mount the drive and copy the needed files to your primary hard disk, then go back to windows and accept the format, than recopy the files
Apr 28, 2010 | Computers & Internet
WD Elements 1tb External HDD media files skipping
Try running Scan Disk and defrag. Otherwise use a program like SpinRite to do a low level scan of the disk.
Good luck
Feb 15, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
I recently reinstalled my OS (Windows XP Media center edition). Ever since i reloaded the OS my WD My Book Home edition 1TB external HDD stopped showing up in the windows explorer as a drive letter. The...
I can't diagnose the drive issue... but I can offer a reliable and trustworthy data recovery solution that I had to use a year ago. It's Seagate's do it yourself data recovery and will work on your WD drive. So if you can't resolve the issue otherwise, consider this as a recovery option...
https://services.seagate.com/diysoftware.aspx
Sep 24, 2009 | Western Digital MY BOOK HOME 1TB EXT...
I have issues while transferring files back from Western Digital 1TB external drive. I copied all my important files there. In explorer all files are showing, but have issue, when you want to open or copy...
Hard drive may be going south and there may be bad sectors on it. Run WD diagnostic program on it and cross your fingers. Do not format the drive - that will erase all. If you do find bad sectors the check disk program will find and block bad sectors and move data in bad sectors to good ones whenever possible. After that you can recover as much as you can but not all because there will be areas where nothing can be read at all depending on the severity of the damage to the sector.
Sep 12, 2017 | Western Digital MY BOOK HOME 1TB EXT...
Computers & Internet Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
