Question about HP RT810UTABA - HP dc7700 small form factor, Core Duo E6300, 80GB hard drive 7200 SATA, no floppy, DVD/... PC Desktop
The disc drive won't open on my hp dc7700
I just got a new work station and when I plug it in it runs diagnostics and booting but the disc drive will not open so that I can insert any disc into it. Please help before I tear it apart.
  • 80 Answers
To force it open you can use a paper clip. Bend it open so you can stick the end of it into a little hole that is right near the disc drive. This will release the spring to allow it to open. The reason it is not opening on it's own, could be that it is no longer getting any power (disconnected cable inside the box) or that the drive itself has failed.
So, first open it up manually with a paper clip and then if nothing happens when you push it back in then either a cable issue or bad drive...
Posted on Feb 13, 2014
5 Suggested Answers
SOURCE: Finding it difficult to install a second hard drive on hp dc7700
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10226&cs_id=1022602&p_id=4863&seq=1&format=2
Posted on Jan 16, 2009
SOURCE: HP DC7700 small form factor.
Are the Keyboard and Mouse USB or Wireless USB. Meaning those Wireless keyboards and mice that you can get and from Microsoft or Logitech. Make sure you have batteries replaced or recharged for your keyboard and mouse. Then see if this solved the problem.
Posted on Oct 05, 2011
SOURCE: HP Pavillion won't recognize Plug n play devices
Look into the Bios or System Setup and make sure Plug and Play is enabled. When you turn the system on notice what key it says to hit to get into the Bios or System Setup. Hit that key and check the Plug and Play to be sure it is enabled.
Posted on Apr 25, 2012
SOURCE: why will my Hp Compaq dc7700 gives red light and wont boot
usually suggests a major failure internally
motherboard
cpu
maybe power supply
Posted on May 26, 2012
Computer booting problem
On some of these, there is an internal circuit breaker on the power supply. You can try unplugging it, hold the power button down for about 30 seconds, then plugging it back in. That can alow the power supply to reset.
May 08, 2013 | Computers & Internet
Media test failure check cable
RUN the software diagnostic coming with the computer and fix it. God bless you
Mar 29, 2013 | HP Compaq dc7700 Ultra-slim Desktop PC -...
My compaq mini atom won't boot shows f9=change boot order,when i press f9 it stops opening
It is most likely that your hard drive has gone bad or is no longer being recognized by the system. Run drive diagnostics check from the BIO and if the drive is faulty, replace the drive.
Jun 03, 2012 | Compaq Computers & Internet
Err1err3
There are several issues that can cause this err1err3 issue. It could be a bad hard disc (or a bad wire between the drive and the motherboard), an incorrect BIOS setting for the SATA hard drive or a problem with the master boot record (MBR). Make sure that there is no disc in the CD drive and disconnect any external storage devices (flash drive). Your computer may be trying to boot from a non-bootable disc.
To check the BIOS setting, turn off the computer and turn it back on. Press F10 continuously to access the BIOS on an HP computer. Some HP computers use F2 or F6. There should be a splash screen that tells you which to use. (If you see the error again, try this step again. It's easy to not have the key press noticed between the POST and the attempt to boot the computer.) Once in the BIOS, go to the Advanced Settings tab (one to the right) and go down to the SATA1 controller option. (Try AHCI.) Then press F10 to save and exit. (Note this isn't part of the BIOS on all HP machines - it does work for some.) See if there is a Diagnostics tab in the BIOS and try running the hard drive test.
Get an hard drive testing utility (ISO) and burn it to CD on another computer. You can set the first boot location when you go into the BIOS as above. With the bootable CD in the drive, restart the computer. (Some machines let you set the one-time boot location by pressing F12 on start up; as with entering the BIOS, it's easy to miss the timing. Just repeat the attempt.)
If the disc tests as good, you can try to repair the MBR. Use a repair tool or an OS install disc for your version of Vista (Home Premium). Boot from the CD as above. With the install disc, follow the on- screen directions and select the Repair option. You will need to enter the Command line mode. You'll need to enter Bootrec with the correct option. For more information, see the following document: http://support.microsoft.com/kb/927392 .
If you possibly can, remove the drive from your current computer before trying the repair. Use a USB/IDE/SATA adapter and another computer, see if the data on the disc can be copied to make a back up. This will work if the disc is still good. (It will also indicate if the cable was the problem if the disc failed the diagnostic tests.)
I hope this helps.
Apr 16, 2012 | HP Pavilion Computers & Internet
Dell Inspiron 9100 running XP boots up but then won't work. Diagnostics results in the fololowing: --DST Short Stats Test-- Test Results: Faill Error Code: 1000-0142 Msg: Unit 4: Drive Self Test...
Hard drive has bad sectors. Before your replace your hard drive when getting this error, try this- Boot from a Windows XP CD and choose Repair at the first prompt to get the recovery console. Type "chkdsk c: /p/r" at the prompt. Repeat until there are no errors found. Exit and reboot. It worked for me.
Jun 14, 2011 | Dell Inspiron 9300 Notebook
My hard drive fails and it wont boot. What is the best solution to it?
If its a HP notebook then perform the har drive self test.
Here are the steps below.
Steps for HDD self test.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If the hard drive fails then surely there is no option other than replacing it....
Please surely buy HP Hard drive.
Jun 14, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
some older sytems don't have the option to add a second hard drive
can you save your files on cd's or travel drive and then install the new hard drive
Jan 16, 2009 | HP RT810UTABA - HP dc7700 small form...
HP RT810UTABA - HP dc7700 small form factor, Core Duo E6300, 80GB hard drive 7200 SATA, no floppy, DVD/... PC Desktop Logo
35 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
