Question about GPS
How long does it take for the sun to complete half of its revolution
  • 7,993 Answers
Various values between 225 and 250 Million years.
Posted on Feb 14, 2014
  • k24674 Feb 19, 2014
    Note : The value range quoted above is for a revolution. For 1/2 a revolution, just divide the value by 2.
Hello. My pulsar 150 UG3 is giving me speed of 47kmp at 4000Rpm which is 3kmp slower than normal as i have another same bike which produce 50kmp at 4000. How it can be corrected? I have consulted to...
Speedometers are not exact and they will vary slightly, even between the same model, year etc.
Tyre size and wear also affect the reading because of the distance travelled with one complete revolution of the wheel. A new tyre with plenty of tread depth will travel further in one revolution than an older worn tyre with less tread depth. If you have two bikes and the tyre treads are different depths, just measure around them both and you will see the different circumferences. Multiply that difference by 100 and you see how much further one will travel than the other in only 100 revolutions and when you think how many times a wheel goes round on a journey, the difference is huge. This puts into perspective the 3KPH difference and also why a tyre seems to wear out quicker once it is down to half the original tread depth......I know mine seem to.
Oct 10, 2010 | 2007 Bajaj Pulsar 150
I have a 91 olds Ninety eight regency elite Intermittently dies code 41 comes up cam sensor circut replaced cam sensor still dies could it be the crank sensor? thank you Michael Dale
cam sensor is only half of the cam circuit, the other half of the cam circuit is the magnet on the timing chain. the cam sensor reads from the magnet every time the engine completes a revolution,
what happens is the magnet on the chain will break into smaller piece which makes the sensor harder to read every time the engine make a complete revolution.
most likely you'll need to replace the timing chain to fix this.
Oct 12, 2009 | 1991 Oldsmobile Ninety Eight Regency
My vacuum died
It might have blown a fuse. ?Check if this model has a fuse
May 16, 2009 | Bissell Lift-Off(R) Revolution(R) Turbo...
Engine will not make complete revolution with spark plug in
Compare the new plug with the old one, if it is longer, it may be sticking into the engine and jamming something.
May 04, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I lost my manual and I'm just trying to find out what the symbols on the front panel mean. I'm particularly interested in knowing what is the difference between the sun and half-sun
The full sun symbol means full heat drying,, and the half sun symbol means half heat drying.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Dryers
Point tha chain timer altima 94
if you mean the timing chain then on your crank gear and your cam gear there will be a mark on each sometimes they look like a dot the dots need to look like this for perfect timing ( . . ) this will be there closest position. Your crank turns once all the way around (360 degree) and your cam gear will do two complete revolutions to the one of the crank gear. so when you set your marks as above when you turn the crank one half turn the mark on the crank gear will be at the bottom and at the same time your cam gear will have made one complete revolution, so when you turn the crank another half turn your cam would have turned again a complete revolution and the two marks should be at their closet point again.
Jan 08, 2009 | 1993 Nissan Altima
AEG 72640 Washing machine
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | AEG Lavamat W1450 Front Load Washer
Playstation2 Slim-Disc only turns in half revolutions
yea im having the same problem cupcake1010
i put in a game but it doesnt even load nothing shows up
it goes straight to bowser and system configuration
any soulutions??? please thanks
Dec 18, 2007 | Sony PlayStation 2 Slimline Console
GPS Logo
16 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
