Question about SpectraVideo Logic 3 Phantom (JT250) Joystick
Logic 3 Phantom (JT250) Joystick - SpectraVideo Logic 3 Phantom (JT250) Joystick
    Top Expert:
  • 14,162 Answers
Posted on Jul 10, 2016
2 Suggested Answers
memturbo
  • 226 Answers
SOURCE: cant find driver download for logic 3 joystick
this website is a different language but it
pretty self explanatory HERE
Posted on Mar 28, 2009
I have a q6 edge with 7" seat lift with the single tower lift and it has always worked but I just lifted it and now it will not come back down.
The good news is that your MOTOR WORKS in at least ONE direction... I would suspect that "Joystick" and the switches inside are at fault!
Here is a decent Link for TROUBLESHOOTING
http://www.quantumrehab.com/pdf/basic-troubleshooting-instructions/infinfb2594_q6_edge_basic_troubleshooting.pdf
PARTS DETAIL
Q6 Edge Replacement Parts
It MAY be called this:
F1 ELE124312 JOYSTICK GIMBLE, DIGITAL, Q-LOGIC 2 but it ain't cheap at $404 + shipping.
THIS MAY work for you:
Hitec 2 Axis Joystick GIM-01 from RobotShop.com
• Aurora 9 Gimbal• Create your own control solution• Can enable or disable self centering on both axis• Feature high sensitivity, 8 ball-bearings, and adjustable tensionThe 2 ... at about $18
AND see THIS Link for other choices:
Search results for Hitec 2 Axis Joystick GIM 01
MOREr designs that are VERY reasonable!
Anthony
Dec 20, 2017 | The Health & Beauty
Can someone fix a DJI Phantom 3 please?
Take it to your local repair facility - fixya does not provide technicians.
Apr 19, 2017 | DJI Innovations Phantom 3 Professional...
I want to attach this joystick to dell 260 gx but i don't have his pot
I couldn't find which kind of connector this joystick uses, but my guess is that it is USB. In which case your computer has 4 USB ports in the back side. If they are full, you can unplug something you don't need (printer for example) and plug the joystick in there.
Feb 13, 2011 | SpectraVideo Logic 3 Tornado (JT251)...
Cant find driver download for logic 3 joystick
Mar 28, 2009 | SpectraVideo Logic 3 Hurricane (JS280)...
SE2200a rapid signal drop off
I had the same problem with my Saffire: the phantom power voltage quickly drops when switched on, causing the mic to cut out. This problem is common in older Saffires, and is well known to Focusrite support (a modification in newer-production units solves the problem).
The problem is that a tiny 100 ohm surface-mount "chip" resistor in the phantom power circuit fails due to insufficient power-handling capability. (This is "R196" in the phantom circuit.)
The fix is to replace the "chip" resistor with a "normal" 1/2 watt metal-film resistor (with wire leads), mounted upright on the circuit board.
I replaced the resistor myself, following directions (and photos) sent to me by Focusrite Tech Support.
The procedure is somewhat fiddly (a Swiss watchmaker could probably do OK). If you've never soldered before, DON'T EVEN TRY THIS, and if you've never worked with surface-mount components, I would ask your electronics-hobbyist buddy to do it for you.
Here is the procedure sent to me by Focusrite:
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SAFFIRE PHANTOM POWER MODIFICATIONS
Dismantling the Unit
Remove the 7 screws on the rear panel.
Remove the 4 screws on the underside of the unit.
Lift away the metal cover.
Remove the 4 small black screws securing the MIDI In/Out sockets.
Remove the single screw securing the S/PDIF In/Out sockets.
Remove the two screws securing this PCB to the chassis.
Gently pull the PCB away from the rear panel and move it through 90 degrees towards the front panel.
Place the unit on its front and support the PCB with some suitable non-conductive item.
Modification Procedure
All the components mentioned are located in the same area on the same PCB (see photo).
It is best to remove the coil and capacitor (as shown in the second photo), as this gives easier access to the components.
Remove R196 and measure its resistance. If it does not measure 100 ohms, replace it.
Use a conventional type (100 ohms metal film, .5 or .6 watt) mounted upright as shown in the photo. Before fitting this resistor, check that the three zener diodes DZ11, DZ12 (22v) and DZ9 (3.3v) are OK and have not shorted out. (Diodes are 500mW, 5% tolerance)
Testing units for Phantom Power problems
Connect a condenser Mic or suitable dummy load* to Channel 1.
Engage +48 switch.
Measure the DC voltage between XLR pins 2 & 1 on Channel 2 Mic Input XLR.
Faulty units usually read around +28Vdc and the voltage gradually drops.
Good unts will measure +48Vdc +/- 0.7Vdc.
* Dummy Load for testing: Solder a 20,000 ohm resistor between pin 2 and pin 1 of a male XLR plug and another 20,000 ohm resistor between pin 3 and pin 1 of the same XLR plug.
Here are the photos:
My Saffire has worked perfectly since I replaced the bad resistor.
Good Luck!
Ken
May 04, 2008 | SE Electronics SE2200A Professional...
SpectraVideo Logic 3 Phantom (JT250) Joystick Logo
286 people viewed this question
Top SpectraVideo Video Game Consoles & Games Experts
James Wishart
Are you a SpectraVideo Video Game Console and Game Expert? Answer questions, earn points and help others
