Question about Sanyo EM-S9515W Microwave Oven
Turn table stopped - Sanyo EM-S9515W Microwave Oven
Microwave Inverter NN-ST651BB 1200W Works fine but the turn table still turn when I open the door.
Does the turn table ever stop? If not you need to either replace the oven or have it repaired, it is likely cheaper to just replace it.
Dec 06, 2016 | Microwave Ovens
Turn table will not turn
I'd check to see if the turntable motor has continuity. If it does, check to see if 120 volts is being supplied to it. If both are o.k., then the motor has probably bound-up in some way internally. There's also the possibility that it has mechanically become detached from the hub that turns the glass tray.
May 06, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
The turn table stopped turning and the unit stopped heating.
the turn table stopped and the unit stopped heating.What should I do?
May 30, 2011 | Goldstar MV-1501 Microwave Oven
Hi, I have a Sharp R-254 microwave and the turn table turns for approx 30 seconds. After 30 seconds it stops and makes a clunking noise, if you open the door and manually turn the glass plate 1/4 of a...
Either the coupler that is located in the center of the oven cavity that the turntable sits on is defective or the turn table motor is defective. . Either repair is rather simple (coupler being the easiest) with parts available online.
Nov 11, 2017 | Sharp R-254 Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave xl1800 has stopped spinning
if the microwave still heats then the turn table motor will need to be replaced.. very easy repair
Jan 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turn Table wont turn
if you can check the turn table motor for resistance. 90 percent would be a broken motor which you could replace. just look for the motor at the bottom of the microwave and race the wire back to the pc board.
i hope i was able to help..
pls rate me
tnx,
drcool
Jul 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Unit does not work
open microve cover find magnetron crimp connections to magnetron
Feb 12, 2007 | Emerson MW8108P Microwave Oven
Sanyo EM-S9515W Microwave Oven Logo
14 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
