Question about Home Meridian Comfort Lift Recliner
Hand control not working how or who can I call to get it fix
    Sergeant:
  • 264 Answers
Home Meridian tech department.............Here's the manufacturer's phone #
1-800-994-3390 Reviews state that the hand controllers fail a lot and the parts department is slow.
Posted on Nov 05, 2014
Sole F63 treadmill controls won't work
Stuck button or bad hand switch. Remove covers between hand rails and console disconnect both hand switches should fix it.
Jul 06, 2014 | Sole Fitness F63 Treadmill
How to fix the Wall-E remote control?
the crystal in the remote control dosent match the crystal in the reciever so you need a new crystal. if its infa-red ten you need the controller that came with it at first but new
May 03, 2013 | Disney Wall-E U-Command Remote Control...
Door motors (controls for the seat adjustment & window operator) won't work unless either the passenger or the driver door is open. How to fix?
take to dealer system is hard to diag even with all info at hand because each door and window has sensors that send singals to a body control that processes and then lets work.
Jul 29, 2012 | 1995 Mercedes-Benz C-Class
My heater isn't working..how do i fix it?
Here's a list of possible culprits:
Priority Action Part Type Cause
1 Inspect - Antifreeze Needed - Coolant Level Low.
2 Inspect - Heater Control Valve - Leaking or Faulty Heater Control Valve.
3 Inspect - Thermostat - Thermostat Stuck Open.
First thing to check is your engine coolant level - quick and free.
Since your blower works, my nominee for the offending part would be the Heater Control Valve, which redirects hot coolant into the passenger compartment heater core. Without hot coolant, the blower will just blow cold air, since the heater core isn't getting the needed flow of hot coolant through it.
There may also be a fault in the "Temperature Valve Actuators" (there is a right hand and a left hand version of these - one for each side of the car).
The Right hand Temperature Valve Actuator is AC Delco part #15-72971.
The Left hand Temperature Valve Actuator is AC Delco part #15-72972.
Their pictures are available in the online AC Delco Parts Catalog at:
http://parts-catalog.acdelco.com/catalog/catalog_search.php
Here are your parts search parameters:
Vehicle: 1996 OLDSMOBILE AURORA V8-244ci 4.0L F/I Vin C ID# 17739
Group / Subgroup: Heating/AC / Heater Core and Htr Control Vlv
Oct 29, 2011 | 1996 Oldsmobile Aurora
I own a Mead LX200 GPS telescope, after automatic alignment the the hand box keys remain locked either on the cable hand box or with the wireless one. What can I do
First thing to do is make sure you have good power-- fresh batteries and or a seperate 12 volt power pack.
Then check the hand controller cable and replace it with a new cable.
Also execute a RESET on the hand controller and send it back to factory default.
If none of these fix the problem try to get a replacement hand controller and see if that works --- if it does your hand controller is bad-- if it does not then a more serious problem with an internal circuit board will require you to return it to Meade for repairs.
http://www.meade.com/support/index.html
Jan 10, 2011 | Meade LX200GPS Telescope
Electric control button raises the head of the Tuffcare hospital bed but will not lower it. It doesn't even make a clicking sound. All other functions are working through the control mechanism. Is there...
The problem you are describing happens quite often and there are several solutions.
1. The manufacturer sometimes supplies a manual crank that fits in the end of the motor to manually turn the motor and lower the bed. This crank is usually lost or misplaced (look for it on the bed frame). With the weight of the mattress and person off of the head you may be able to use a pair of pliers or other tool to carefully turn the motor shaft.
2. There is a bolt and nut at the end of the head motor shaft or a hitch pin and bolt. Remove this bolt at the end of the motor shaft where it attaches to the head frame and the head frame will drop to level.
3. Fixing the hand control usually involves taking the two halves apart and bypassing the push-button switch by shorting across the head down switch. This is the best way to diagnose a bad hand control. This is the most difficult solution for the average end user. You ultimately will purchase a new hand control anyway so this may be a viable solution. The hand control gets the most use and abuse and is usually the faulty part.
You may have a bad relay on the junction box control board where all the motors and hand control are plugged in. If the motor runs in one direction, the motor is OK. If you have the micro-switch style 6 button switch hand control you may be able to clean the switches by spraying contact cleaner is the switches and pushing them several times. Check the hand control plug for bent or bad pins at the control board junction box. The hand control pendant runs about $100 and the junction box controller is about $400. Hope this helps.
Nov 27, 2010 | Health & Beauty
The autostar on my ds-2114 ats has stopped working. new battiers were installed & power light works but no reads outs on hand controller.
Could just be a bad cable. See if you can find a new one or buy a new one from Meade.
www.meade.com
You can also try reversing the cable. (depends on the Meade telescope). If a new cable does not fix it, then you will have to buy a new controller. Never plug or unplug the hand controller while the scope is turned ON.
Jan 01, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Parrot CK3100 lcd control isn't working.
try pushing the wire into the bottom of the display, this comes loose easily and causes these problems.
Oct 21, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
I HAVE THE WIRELESS MOUSE ATTACHED TO MY COMPUTER AT WORK. I ALSO HAVE A REMOTE COMPUTER (VPN) WITH A CORDED MOUSE AND KEYBOARD. THE MOUSE KEYS AT MY HOUSE NOW HAVE REVERTED TO RIGHT HANDED. I AM LEFT...
go into your control panel. should have a mouse settings. you can change to left hand there.
Click on start then control panel look for mouse settings.
Jun 10, 2009 | Computers & Internet
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Home Meridian Comfort Lift Recliner Logo
137 people viewed this question
Top Home Meridian Furniture Experts
Peter
Peter
Tom Chichester
MobilityRepairSpecia...
Level 1 Expert
Are you a Home Meridian Furniture Expert? Answer questions, earn points and help others
