Question about Dell E173FP 17" LCD Monitor
Dell E173FP Monitor Problem
After starting computer the monitor's screen will come on only momentarily then shut off.  The computer continues to run but no monitor activity.
When I try turning the monitor off then on again, it will go through this identical cycle of coming on for just a few seconds then shutting off.
  • 12 more comments
  • windje Nov 04, 2007
    I have Identical problem - can get monitor to stay on by slamming against desk and then never turning off computer.
    Also try resetting monitor to all factory settings.
  • Anonymous Nov 14, 2007
    I have a 15" LCD monitor that is doing the same thing. If any of you figure it out please e-mail me @
  • jaz0056 Feb 12, 2008
    when I turn on my monitor the screen appears for a second then it goes black and when I even plug the cable that is connected to the computer notthing appears on the screen. what should i do ?
  • raza5 Feb 13, 2008
    Dell E173FPb 17" LCD Flat Panel Monitor. The power light comes on; a video image flashes on the screen and then goes blank.
  • Walesa74 Feb 21, 2008
    monitor comes on for half hr then shuts off, when restarted it stays on for a minute or so then of again then just repeats like that.
  • rshaley Mar 09, 2008
    Monitor turns on for 1-2 seconds and then goes off at start up. If I turn the monitor off and back on it repeats the same issue.
  • Anonymous Mar 11, 2008
    Monitor stats up for a moment then blackout while still on. Have to keep turning on and off to warm it up then it stays on eventually.
  • Anonymous Mar 14, 2008
    monitor turns off frequently
  • Anonymous Mar 17, 2008
    Same problem here, with the 19" model. green light on the LCD power button, goes on for only a second or two then just blacks out. Power button stays green, PC is still running. When I put it off and power it on again, displays an image but blacks out again after 1 second. Tried another monitor (CRT), everything is OK. Tried the LCD monitor on another PC, same problem.
  • Viper-xp Mar 30, 2008
    Monitor went blank (black) while using it. Will not run Self Test (disconnected from PC per Dell Instructions) and Power Switch Blinks Green On and OFF all the time (it will no longer switch the monitor off). Unit as manufactured in Nov 2004.
  • Anonymous Apr 03, 2008
    Yep, same monitor, same exact problem.
  • pickledx3 Sep 16, 2008
    Monitor goes dark then turns back on. Repeats about every 20 seconds.
  • jimmyboxall Jan 03, 2009
    Exactly the same problem. Turn the monitor off then on it comes on for 2 seconds then turns off.
  • Arley46 Feb 26, 2009
    Same thing: During power up the screen will light up for a second then go dark. I've replaced my 17" Dell with a 19" HP and everything is working fine. I'd like to repair the Dell for my other system.
My Dell E173FPc exhibited this same problem as described by many people on this site. Having looked through the solutions I decided to investigate further.
Posted solutions point to a faulty 12V smoothing capacitor, dry joints on the inverter transformer or faulty driver transistors. All these were Ok in my case, but on closer inspection a dry joint was found on L202 – see picture.
Cleaning off the old solder and re-soldering fixed the problem.
So if your monitor exhibits the same symptoms carefully inspect all the solder joints of large components around the inverter.
Posted on Feb 10, 2009
I think it is the inverter board on your monitor. If you can dimly see the display wheh holding a flashlight to it, then that is
your problem. The invertor is not back lighting the screen and that is why you cannot see the image.
Posted on Dec 17, 2007
  • 138 Answers
This is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. It can be easily replaced. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 13, 2008
  • Somsak Tantong
    Somsak Tantong Feb 18, 2008
    Did you try your monitor with another computer? If not, you should test your monitor with different computer and see how it performs.
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 848 Answers
Dell E173FP Monitor Problem? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From can find those parts
if you have any question,please let us know,we sincerely hope we can help you!
you can also check this boards whether suit you:
1521HSD1 715L1074 PWPC1521XXD1 Dell ADTV1521HSD1 Power Supply Backlight...
Posted on Feb 11, 2015
I found this web page that shows what the problem is and how to fix it. This is for a 15 inch monitor but I'm sure its the same for the 17 inch
Posted on Jan 01, 2009
  • 33 Answers
I replaced the 1000uf 16v cap on my 15 inch (the original was swollen) and it seems to work fine now. I must sonfess though that I didn't use a proper replacement, I just gutted a 2200uf 16v cap from a burnt power supply.
Posted on Mar 28, 2008
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
Monitor runs fine for a few hours then shuts down
Its overheating so your better off getting a new one
Jan 22, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Menu button doesnt give the menu, also continuous auto adjusting at random times! The adjusting stops when i turn the monitor off and back on. All help will be much appreciated!! >_< Its annoying and...
The constant auto-adjust pop-up is a indication that the power supply is about to die. As the voltage varies the monitor control board momentarily resets and you get the adjust screen. We have a step by step repair guide posted on our web site at: Check he sticker on the back of your monitor for the last letter to determine the version of the E173 that you have. The letters will be either c,f or b.
I hope this helps, if so please rate our solution.
Corporate Computer
Dec 29, 2009 | Dell E173FP 17" LCD Monitor
Video displays momentarily when monitor is first turned on, then screen goes black. Problem repeats when monitor is turned off and then back on.
Check our web site at: We have step by step repair guides for each of the versions of the E173FP monitor.
I hope this helps, If so please rate our solution.
Corporate Computer
Nov 23, 2009 | Dell E173FP 17" LCD Monitor
My DELL LCD monitor keeps flashing after the computer shuts down
Try to set the monitor in the factory setting this will discharge the monitor and restore it in the factory settings.
unplug the vga cable from the back of the monitor while the poewr to the monitor is on and look for the band of colors it will move around the screen it will give red, green,blue and white color if they are the proper colors all over the screen that means the monitor is fine the problem is with the video card or the cable and, if the monitor does not gives proper color replace the monitor... any queries revertt back
Sep 17, 2009 | Dell E173FP 17" LCD Monitor
Dell E173FP monitor on Visa
Are you putting in the Dell color monitor Cd to install the monitor ?
The new computer should not require,any drivers as its plug and play
Jul 27, 2008 | Dell E173FP 17" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Monitor Logo
5,403 people viewed this question
Alun Cox
